Paul mps62
Post subject: Introduction Posted: Wed Jun 03, 2015 5:46 pm |
Joined: Sun May 24, 2015 4:02 pm Posts: 6 Location: Farnborough Vehicle: MPS3 mkII
Has thanked: 10 times
Hi to all, Just recently joined, I'm Paul and I come from Farnborough in Hampshire. I've recently purchased an MPs 59 reg mk2 (black) " best colour " so I've read by others .Well pleased with it but have plans for a remap in the not to distant future. Cheers
Post subject: Re: Introduction Posted: Wed Jun 03, 2015 5:52 pm |
 Have you read up on where to goeth and who to avoid? You'll want HPFP internals first before a map
Post subject: Re: Introduction Posted: Wed Jun 03, 2015 7:09 pm |
 along
Gouldy
Post subject: Re: Introduction Posted: Wed Jun 03, 2015 7:14 pm |
Joined: Sat Mar 14, 2015 3:01 pm Posts: 989 Location: Sherborne Vehicle: MPS6
Has thanked: 168 times
Been thanked: 113 times
 along to
_________________ Precision turbo 6266~CPE manifold~Tial 44mm EWG~CPE dp~Wiesco pistons~Manley rods~balanced and keyed crank~pulley and flywheel~Ported head with uprated valves and springs~Grimspeed 3 port EBCS~Stratified Guardian Angel with 4bar map sensor~Egr blanking plate~South Bend stage 3 endurance clutch kit with flywheel~Braided clutch line~Mishimoto R Line FMIC~JBR true 3" stage 2 intake~AWR 88 duro rem~JBR 70 duro engine side mounts~Polished rocker cover~JBR ssp and weight~plus weighted gear knob~White widow rear diff brace~BC coilovers~Whiteline RARB~Team Dynamics Imola 19" wheels in black~235/35r19 Uniroyal Rainsport 3's~K Sport 8pot calipers with 356mm front discs and yellow stuff pads~Stoptech rear discs and pagid pads~Garage door lip splitter~Versa tuner~Stainless dials. Most importantly, J Tune!!!!!
BanzaiMike
Post subject: Re: Introduction Posted: Thu Jun 04, 2015 3:01 pm |
Joined: Sun Sep 16, 2012 8:00 pm Posts: 2275 Location: Stockport Vehicle: MPS2
Has thanked: 3 times
Been thanked: 26 times
Hi and welcome along.
We have a nice beginners guide to the cars and how best to safely mod them, hope you enjoy your purchase
_________________ New motor - 2015 Mazda 2 Skyactiv 115 Sport Nav Previous motor - 2010 Mazda 3 MPS running BNR S3 Snail and the usual bolt ons.
Test Drives Unltd
Post subject: Re: Introduction Posted: Thu Jun 04, 2015 9:13 pm |
Joined: Tue Jan 11, 2011 10:48 pm Posts: 1579 Location: West Sussex Vehicle: Toyota
MAWV
Post subject: Re: Introduction Posted: Sat Jun 06, 2015 10:34 pm |
Joined: Mon May 04, 2015 10:00 am Posts: 126 Vehicle: MPS3 mkII
Been thanked: 3 times
Good colour choice :-). Welcome to the forum.
BLUNTY
Post subject: Re: Introduction Posted: Sun Jun 07, 2015 7:37 am |
Joined: Sun Feb 13, 2011 1:23 pm Posts: 367 Location: Sunderland Vehicle: MPS3 mkI aero
Been thanked: 15 times
_________________ Mazda MPS 3 Aero (2008) MK1 BNR3 (fitted 56,000 Miles) Corksport HPFP Cobb AP V3 Corksport Tmic HTP 3" Full Intake (fitted 56,000 Miles) Cobb 3-Port Boost Control Solenoid 235/40/18,Eagle F1 Winter/ Eagle F1 245/40/18 (Summer) mazdaspeed Ariel BC Coilovers Removed the splash guard and resonator box Febi Bilstein Prokit Rear Drop Links Short Shift Plate(Spamface) CFM Rear Motor Mount (9 PEGS) JBR Pass Motor Mount 80a JBR Trans Motor Mount 88a JBR 125 RARB (Middle setting) Forge V2 BPV Stoptech Drilled Slotted Front/Rear Step colder NGK 6510 0.7mm gap (fitted 56,000 Miles) APT Long Downpipe EGR Delete (fitted 56,000 Miles) Coolant bypass RX8 Alloys 3Bar Map Sensor and Harness (fitted 56,000 Miles) Banjo Bolt Motul GEAR 300 LS 75W-90 Fully Synthetic Car Limited Slip Differential Oil(Changed@59,292) Shell Helix Ultra 5W-40 Fully Synthetic Engine Oil ( Changed every 6/7000 miles) MOTS DONE@ Ambleside Motors
Kenny
Post subject: Re: Introduction Posted: Sun Jun 07, 2015 12:31 pm |
Been thanked: 11 times
Paul mps62
Post subject: Re: Introduction Posted: Mon Jun 08, 2015 5:50 pm |
Hi ,just a thank you for the welcomes received ,l look forward to getting to use the forum and the very useful information available. Paul
