Page 1 of 1 [ 13 posts ]
 Post subject: Hi!
 Post Posted: Tue May 26, 2015 7:57 pm
Hi all,
My names Ben from the West Midlands. I Bought my 2010 crystal white MK2 3 MPS with 39k on the clock a couple of months ago and loving it so far! I look forward to looking about the forum and speaking to you all on all things MPS!
 Post subject: Re: Hi!
 Post Posted: Tue May 26, 2015 9:01 pm
Been thanked: 19 times
welcome to the forum, get some photos up :wwp: :mpsoc: :welcome:
 Post Posted: Tue May 26, 2015 9:47 pm
Welcome to the :mpsoc: forum.
Good to see you bought a Mk2 in the best colour :thumbs:
 Post Posted: Wed May 27, 2015 12:22 am
Hi Ben and :welcome: to the club :thumbs:
 Post Posted: Wed May 27, 2015 6:30 am
:welcome: to :mpsoc: ben..... :wwp:
 Post Posted: Wed May 27, 2015 7:18 am
Cheers all. Will put some up ASAP.
 Post Posted: Wed May 27, 2015 7:26 am
Hello and welcome. :)
 Post Posted: Wed May 27, 2015 3:16 pm
Welcome to the forum dude :)
haweh wherw be the pics? :p
 Post Posted: Wed May 27, 2015 3:36 pm
:welcome: :mpsoc: Let the Tunning Begin :thumbs:
 Post Posted: Thu May 28, 2015 9:43 pm
Hi and Welcome to the Family
 Post Posted: Fri May 29, 2015 8:38 am
 Post Posted: Tue Jun 02, 2015 12:05 pm
 Post Posted: Sat Jun 06, 2015 5:56 pm
Apologies for how long it's took for a pic, had a few things to get done. Wheel refurb & SRI first on the agenda.
Users browsing this forum: No registered users and 14 guests
