khyberu
Post subject: NEW MPS6 OWNER!! HELLO ALL... Posted: Fri Apr 10, 2015 2:48 pm |
Hello to you all. I have recently just purchased a Mazda 6 mps and must say it is a cracking car. The car is standard with full mazda service history, 2 owners from new!. I would like some advice on the handling. The car feels abit "OO STEADY ON"  now i imagine, all you lovely forum users will throw all sorts of different ideas at me but i am interested in a mid range type of item to replace stock i.e alot better than stock but not as pricey as race car... Once iv sorted out the handling and made it stiffer with better roll resistance can you guys point me to a nice spoiler to replace stock and some suttle, aggresive looking alloys, splitters and general mods to improve the car. Thanks a million! (if someone could link some topics i could find usefull in terms of tuning, faults or good garages to use in the midlands for the mps i would be grateful. Cheers guys
Post subject: Re: NEW MPS6 OWNER!! HELLO ALL... Posted: Fri Apr 10, 2015 7:30 pm |
  Handling.... B8's with H&R springs, far better than oem and eibachs but cheaper than a full coilover setup. Engine bay brace, brace behind the back seats , rear arb (I suggest doing diff mounts while there as will save a lot of labour) H brace across the underside of the car. I have some side mounts too that not many have. All the above make the 6 reasonable at handling and nearly compete with the likes of a STI Impreza
Gouldy
Post subject: Re: NEW MPS6 OWNER!! HELLO ALL... Posted: Fri Apr 10, 2015 8:25 pm |
Joined: Sat Mar 14, 2015 3:01 pm Posts: 989 Location: Sherborne Vehicle: MPS6
Has thanked: 168 times
Been thanked: 113 times
Hi and  6 is a great car.
_________________ Precision turbo 6266~CPE manifold~Tial 44mm EWG~CPE dp~Wiesco pistons~Manley rods~balanced and keyed crank~pulley and flywheel~Ported head with uprated valves and springs~Grimspeed 3 port EBCS~Stratified Guardian Angel with 4bar map sensor~Egr blanking plate~South Bend stage 3 endurance clutch kit with flywheel~Braided clutch line~Mishimoto R Line FMIC~JBR true 3" stage 2 intake~AWR 88 duro rem~JBR 70 duro engine side mounts~Polished rocker cover~JBR ssp and weight~plus weighted gear knob~White widow rear diff brace~BC coilovers~Whiteline RARB~Team Dynamics Imola 19" wheels in black~235/35r19 Uniroyal Rainsport 3's~K Sport 8pot calipers with 356mm front discs and yellow stuff pads~Stoptech rear discs and pagid pads~Garage door lip splitter~Versa tuner~Stainless dials. Most importantly, J Tune!!!!!
Post subject: Re: NEW MPS6 OWNER!! HELLO ALL... Posted: Fri Apr 10, 2015 8:33 pm |
 along
khyberu
Post subject: Re: NEW MPS6 OWNER!! HELLO ALL... Posted: Fri Apr 10, 2015 8:50 pm |
Sir-SpamFace wrote: :welcome:  Handling.... B8's with H&R springs, far better than oem and eibachs but cheaper than a full coilover setup. Engine bay brace, brace behind the back seats , rear arb (I suggest doing diff mounts while there as will save a lot of labour) H brace across the underside of the car. I have some side mounts too that not many have. All the above make the 6 reasonable at handling and nearly compete with the likes of a STI Impreza Where can i access most these items from, is there a website?
JB21
Post subject: Re: NEW MPS6 OWNER!! HELLO ALL... Posted: Sat Apr 11, 2015 8:07 am |
Joined: Tue Jul 01, 2014 7:15 am Posts: 3053 Vehicle: other
Has thanked: 53 times
Been thanked: 115 times
Sir-SpamFace wrote: :welcome:  Handling.... B8's with H&R springs, far better than oem and eibachs but cheaper than a full coilover setup. Engine bay brace, brace behind the back seats , rear arb (I suggest doing diff mounts while there as will save a lot of labour) H brace across the underside of the car. I have some side mounts too that not many have. All the above make the 6 reasonable at handling and nearly compete with the likes of a STI ImprezaSo it will understeer like a bitch then.
_________________ Mondeo ST155: Daily commuter
BMW i3 ReX: Evening & weekend town car
Renault Clio 182 FF: Track toy
Post subject: Re: NEW MPS6 OWNER!! HELLO ALL... Posted: Sat Apr 11, 2015 8:13 am |
JB21 wrote: Sir-SpamFace wrote: :welcome:  Handling.... B8's with H&R springs, far better than oem and eibachs but cheaper than a full coilover setup. Engine bay brace, brace behind the back seats , rear arb (I suggest doing diff mounts while there as will save a lot of labour) H brace across the underside of the car. I have some side mounts too that not many have. All the above make the 6 reasonable at handling and nearly compete with the likes of a STI ImprezaSo it will understeer like a bitch then. All AWD cars under steer , it's part of their trait, but really push them hard and they'll snap in and over steer.
JB21
Post subject: Re: NEW MPS6 OWNER!! HELLO ALL... Posted: Sat Apr 11, 2015 8:18 am |
khyberu wrote: Sir-SpamFace wrote: :welcome:  Handling.... B8's with H&R springs, far better than oem and eibachs but cheaper than a full coilover setup. Engine bay brace, brace behind the back seats , rear arb (I suggest doing diff mounts while there as will save a lot of labour) H brace across the underside of the car. I have some side mounts too that not many have. All the above make the 6 reasonable at handling and nearly compete with the likes of a STI Impreza Where can i access most these items from, is there a website? Just start of with this set up mate, this will give best improvement for less than £700 Attachment: Screenshot_2015-04-11-09-16-11.png
khyberu
Post subject: Re: NEW MPS6 OWNER!! HELLO ALL... Posted: Sat Apr 11, 2015 8:36 am |
JB21 wrote: khyberu wrote: Sir-SpamFace wrote: :welcome:  Handling.... B8's with H&R springs, far better than oem and eibachs but cheaper than a full coilover setup. Engine bay brace, brace behind the back seats , rear arb (I suggest doing diff mounts while there as will save a lot of labour) H brace across the underside of the car. I have some side mounts too that not many have. All the above make the 6 reasonable at handling and nearly compete with the likes of a STI Impreza Where can i access most these items from, is there a website? Just start of with this set up mate, this will give best improvement for less than £700 Attachment: Screenshot_2015-04-11-09-16-11.png Thanks pal, i will have a look into this setup as it seems right. Will the springs bring it down alot as i live in a speed bump area? Where can i buy the diff mounts from?
khyberu
Post subject: Re: NEW MPS6 OWNER!! HELLO ALL... Posted: Sat Apr 11, 2015 8:38 am |
JB21 wrote: Sir-SpamFace wrote: :welcome:  Handling.... B8's with H&R springs, far better than oem and eibachs but cheaper than a full coilover setup. Engine bay brace, brace behind the back seats , rear arb (I suggest doing diff mounts while there as will save a lot of labour) H brace across the underside of the car. I have some side mounts too that not many have. All the above make the 6 reasonable at handling and nearly compete with the likes of a STI ImprezaSo it will understeer like a bitch then. What would you advise?
Gav1888
Post subject: Re: NEW MPS6 OWNER!! HELLO ALL... Posted: Sat Apr 11, 2015 8:47 am |
Has thanked: 56 times
Been thanked: 28 times
~Divine~Wind~
Post subject: Re: NEW MPS6 OWNER!! HELLO ALL... Posted: Sat Apr 11, 2015 9:45 am |
Joined: Fri Sep 06, 2013 7:45 pm Posts: 2813 Location: North-East, Newcastle Vehicle: MPS6
Has thanked: 5 times
Been thanked: 136 times
Shocks will be cheaper from Demontweeks last time I looked. Springs cheaper on amazon :p Welcome to the forum mate  The setup above made a noticeable change to my 6
_________________ Mazda 6 MPSMazda 6 MPSMazda 6 MPSHelpful threads http://tinyurl.com/kjykgbdEdge 2016 Groupbuy #2 - viewtopic.php?f=84&t=24079
BanzaiMike
Post subject: Re: NEW MPS6 OWNER!! HELLO ALL... Posted: Sun Apr 12, 2015 9:40 am |
Joined: Sun Sep 16, 2012 8:00 pm Posts: 2275 Location: Stockport Vehicle: MPS2
Has thanked: 3 times
Been thanked: 26 times
And and welcome to the family
_________________ New motor - 2015 Mazda 2 Skyactiv 115 Sport Nav Previous motor - 2010 Mazda 3 MPS running BNR S3 Snail and the usual bolt ons.
Post subject: Re: NEW MPS6 OWNER!! HELLO ALL... Posted: Sun Apr 12, 2015 12:26 pm |
khyberu wrote: JB21 wrote: Sir-SpamFace wrote: :welcome:  Handling.... B8's with H&R springs, far better than oem and eibachs but cheaper than a full coilover setup. Engine bay brace, brace behind the back seats , rear arb (I suggest doing diff mounts while there as will save a lot of labour) H brace across the underside of the car. I have some side mounts too that not many have. All the above make the 6 reasonable at handling and nearly compete with the likes of a STI ImprezaSo it will understeer like a bitch then. What would you advise? See my sig, apart from coilovers, I've pretty much every single handling mod there is for a 6.
khyberu
Post subject: Re: NEW MPS6 OWNER!! HELLO ALL... Posted: Sun Apr 12, 2015 1:20 pm |
Sir-SpamFace wrote: khyberu wrote: JB21 wrote: Sir-SpamFace wrote: :welcome:  Handling.... B8's with H&R springs, far better than oem and eibachs but cheaper than a full coilover setup. Engine bay brace, brace behind the back seats , rear arb (I suggest doing diff mounts while there as will save a lot of labour) H brace across the underside of the car. I have some side mounts too that not many have. All the above make the 6 reasonable at handling and nearly compete with the likes of a STI ImprezaSo it will understeer like a bitch then. What would you advise? See my sig, apart from coilovers, I've pretty much every single handling mod there is for a 6. That setup looks amazing! Iv got around £3000 to spend on a good setup or i might spend it on a bike im not sure which one... i would love to build a great car its always been my dream so im tempted. What can 3k get me in terms of a overall handling to power setup? A rough estimate is fine...
