doddy
Post subject: whos best for tuning? Posted: Thu Mar 19, 2015 2:38 pm |
Joined: Thu Mar 19, 2015 12:57 pm Posts: 5 Location: thetford Vehicle: MPS3 mkI aero
hi all, I've recently bought myself a mps3 and am looking to tune her up! so I went out and bought versatune thinking it was easy to use  how wrong was I after days of looking and playing around I have come to the conclusion that it is a bit beyond me at this present time with my limited knowledge of turbo tuning and the last thing I want to do is hurt my new baby so I was wondering if their was anybody on the forum who I could get to tune my mps3 up? many thanks Doddy
DaveEdin
Post subject: Re: whos best for tuning? Posted: Thu Mar 19, 2015 2:53 pm |
Joined: Sun Jul 29, 2012 12:35 pm Posts: 1143 Location: Edinburgh, Scotland Vehicle: MPS6
Has thanked: 24 times
Been thanked: 43 times
Bhp: 280
lbf·ft: 295
Find yourself DJJUT and ask him nicely. You'll need a Cobb Accessport or VersaTuner as well as a PC/laptop (which presumably you have). There's a reason he gets called Mr Wizard, and it's not because he knows magic tricks... He does, but that's not why he's called Mr Wizard.
doddy
Post subject: Re: whos best for tuning? Posted: Thu Mar 19, 2015 3:00 pm |
yes mate I have versatune already  thanks for the heads up dave I will send him a pm and se how I get on from their m,any thanks Doddy
Post subject: Re: whos best for tuning? Posted: Thu Mar 19, 2015 3:06 pm |
justin is the main man. But get hpfp internals first or he won't touch it. Should be the first thing you got really
doddy
Post subject: Re: whos best for tuning? Posted: Thu Mar 19, 2015 3:32 pm |
ok thanks sir_spamface, I have pm`d him so I will se what he says  I've been told by bbr that the stock pump should be ok up to 290bhp is this not the case?
EliotG
Post subject: Re: whos best for tuning? Posted: Thu Mar 19, 2015 3:44 pm |
Joined: Wed May 01, 2013 10:36 am Posts: 566 Vehicle: MPS3 mkI aero
Been thanked: 9 times
I've been tuned without HPFP internals, but I'm still going to get them just to be on the safe side. Then Justin can give it even more beans.
_________________ Mods: JBR SRI/TIP || JBR Shifter Bushings || SF SSP || Custom 2nd Decat + Silencer || Forge v2 BPV || Cobb v2 || J-Tune || Bilstein B8
doddy
Post subject: Re: whos best for tuning? Posted: Thu Mar 19, 2015 3:51 pm |
Thanks eliot I do have them on my wish list to get
sternritter
Post subject: Re: whos best for tuning? Posted: Thu Mar 19, 2015 4:10 pm |
Has thanked: 7 times
Been thanked: 10 times
There is no "best" person , the big hitters can all get you where you want to be.
You have :
purple drank ray dagher freektune
Freek is probably the biggest in the world , purple drank dont tune versa the last time i heard.
Post subject: Re: whos best for tuning? Posted: Thu Mar 19, 2015 4:55 pm |
Freek Tune FTW
gronow89
Post subject: Re: whos best for tuning? Posted: Thu Mar 19, 2015 5:21 pm |
Joined: Tue May 08, 2012 8:40 pm Posts: 4176 Location: bridgend, south wales Vehicle: MPS3 mkI aero
Has thanked: 19 times
Been thanked: 46 times
Since when has anyone recomended freaktune etc over jtune?
_________________ Wisseco pistons, Manley h beam rods, Arp main stud kit, Arp head stud kit, Fidanza ali flywheel, Cpe Balance shaft delete, Damond Egr delete kit, Inlet manifold butterfly delete, Coolent bypass, Cpe injector seals, Htp 3" intake, Aem cone filter, Bnr stage4 turbocharger, Grimspeed 3port bcs, Bosch 3bar map sensor, Ngk 1 step colder, 3" catless downpipe, 2nd decat delete, Cxracing custom pipes, Treadstone tr8 fmic, Sure short shift kit, Mme solid shifter bushes, Custom 676g gear knob, Xspower manifold, Devils own meth injection, Forge recirc valve, Autotech hpfp, Jbr thermal intake gasket, Hel stainless lines, Rear defuser, jbr air dam, Mk2 alloys, Versatuner.
Gav1888
Post subject: Re: whos best for tuning? Posted: Thu Mar 19, 2015 5:28 pm |
Has thanked: 56 times
Been thanked: 28 times
DJJUT^^^^^^^^ is who u want.. But get HPFP internals first especially on mk2  And  to
sternritter
Post subject: Re: whos best for tuning? Posted: Thu Mar 19, 2015 5:32 pm |
gronow89 wrote: Since when has anyone recomended freaktune etc over jtune? The man himself lol . How many other tuners have you tried. They are all good imo.
gronow89
Post subject: Re: whos best for tuning? Posted: Thu Mar 19, 2015 5:46 pm |
Im not saying they arent. But uk wise jtune is best.
sternritter
Post subject: Re: whos best for tuning? Posted: Thu Mar 19, 2015 6:12 pm |
gronow89 wrote: Im not saying they arent. But uk wise jtune is best. Isn't that the beauty of e-tuning , the mapper could live on the moan as-long as he has at-least a dial up connection you will get that map It would be good if justin had the PRO version of ATR and people could go down get tuned in a day with him in the car live mapping .
Post subject: Re: whos best for tuning? Posted: Thu Mar 19, 2015 6:55 pm |
People are quite welcome to come to me with their Cobb or VT and get a tune sorted....... don't need pro for that [WHITE SMILING FACE]
Users browsing this forum: No registered users and 6 guests |
