 Post subject: new car!
 Post Posted: Tue Feb 24, 2015 11:49 am
Hello everyone.
New to the forum, and don't actually have a car yet...
But deposit down... I'm looking at a silver MK1 2009 3 Aero, factory settings.
Been out on test drives (taken out twice on separate days on my own, and had a good look round, with amazing buyers guide as my wingman - thanks to everyone), so hope the one I want isn't a duffer.
No pics yet, but when I pick it up (hopefully at the weekend), I will update.
have driven total guff all my life except a brief flirtation with a Cooper S (before the nippers came along).
so pretty excited!
More to follow...
Doug.
 Post subject: Re: new car!
 Post Posted: Tue Feb 24, 2015 12:16 pm
Hello and a warm :welcome: to :mpsoc: :thumbs:
 Post Posted: Tue Feb 24, 2015 12:29 pm
Has thanked: 53 times
Been thanked: 115 times
:welcome: to the :mpsoc:. :wwp:
Mondeo ST155: Daily commuter
BMW i3 ReX: Evening & weekend town car
Renault Clio 182 FF: Track toy
 Post Posted: Tue Feb 24, 2015 12:34 pm
 Post Posted: Tue Feb 24, 2015 12:43 pm
 Post Posted: Tue Feb 24, 2015 2:01 pm
Been thanked: 19 times
Good to see the buyers guide being used. Welcom along buddy
 Post Posted: Tue Feb 24, 2015 5:51 pm
lbf·ft: 322
Welcome to MPSOC,
Best choice you could of made there, Mk1 in silver. :)
 Post Posted: Tue Feb 24, 2015 6:18 pm
:welcome: along :thumbs:
 Post Posted: Tue Feb 24, 2015 6:53 pm
Has thanked: 25 times
Been thanked: 122 times
Hi and welcome to the club
Used to have : 2008 MK1 3MPS Cosmic Blue - Image J-Tuned, stainless steel dials, eBay TIP, Sure SSP, Sure Anchors, K&N Replacement, Drilled Airbox, LED side lights, LED interior lights, LED reverse light, MTEC drilled discs, Yellow Stuff pads, NGK LTR7IX-11, EGR block off.
Now: 2005 Corolla T-Sport
 Post Posted: Tue Feb 24, 2015 7:25 pm
Bhp: 387
lbf·ft: 366
:welcome: to :mpsoc: :)
 Post Posted: Tue Feb 24, 2015 9:04 pm
Been thanked: 9 times
Hello! Welcome along. Where are you based?
Mods: JBR SRI/TIP || JBR Shifter Bushings || SF SSP || Custom 2nd Decat + Silencer || Forge v2 BPV || Cobb v2 || J-Tune || Bilstein B8
 Post Posted: Tue Feb 24, 2015 11:19 pm
 Post Posted: Wed Feb 25, 2015 9:13 am
Hi and welcome along!
 Post Posted: Thu Feb 26, 2015 1:54 pm
 Post Posted: Thu Feb 26, 2015 6:05 pm
Hi and welcome to the family :mpsoc:
