b_rutter
Post subject: Hi! Posted: Tue May 26, 2015 7:57 pm |
Hi all, My names Ben from the West Midlands. I Bought my 2010 crystal white MK2 3 MPS with 39k on the clock a couple of months ago and loving it so far! I look forward to looking about the forum and speaking to you all on all things MPS!
FarmerChris
Post subject: Re: Hi! Posted: Tue May 26, 2015 9:01 pm |
Joined: Sun Jul 28, 2013 9:31 am Posts: 1311 Location: west cumbria Vehicle: MPS6
Been thanked: 19 times
_________________ Gtx2867R Turbo, RX8 Seats, Bilstein B8 Dampers, H&R -35mm Springs, HDI GT2 FMIC, Whiteline 24mm Rear ARB, AWR 70d REM, CPE & Sure Rear Diff Mounts, Spam SSP, HTP 3" Intake, Forge v2 Recirc, Long Downpipe, R-Spec Boost Gauge, Cobb Ap V2, Autotech Hpfp, Cobb 3 Port BCS, 3bar MAP Sensor, EGR Block Off, Throttle Body Coolant Bypass, JBR TIG's, VTCS Removal, DIY intake porting, Toyota Injector Seals. DJJUT Tune! Farmer Chris Build Thread --> http://mpsowners.co.uk/viewtopic.php?f=180&t=16911
SilverSport
Post subject: Re: Hi! Posted: Tue May 26, 2015 9:47 pm |
Joined: Thu Feb 27, 2014 3:56 pm Posts: 665 Vehicle: other
Been thanked: 15 times
Welcome to the  forum. Good to see you bought a Mk2 in the best colour
Post subject: Re: Hi! Posted: Wed May 27, 2015 12:22 am |
Hi Ben and  to the club
Gav1888
Post subject: Re: Hi! Posted: Wed May 27, 2015 6:30 am |
Has thanked: 56 times
Been thanked: 28 times
b_rutter
Post subject: Re: Hi! Posted: Wed May 27, 2015 7:18 am |
Cheers all. Will put some up ASAP.
Post subject: Re: Hi! Posted: Wed May 27, 2015 7:26 am |
Hello and welcome.
~Divine~Wind~
Post subject: Re: Hi! Posted: Wed May 27, 2015 3:16 pm |
Joined: Fri Sep 06, 2013 7:45 pm Posts: 2813 Location: North-East, Newcastle Vehicle: MPS6
Has thanked: 5 times
Been thanked: 136 times
BLUNTY
Post subject: Re: Hi! Posted: Wed May 27, 2015 3:36 pm |
Joined: Sun Feb 13, 2011 1:23 pm Posts: 367 Location: Sunderland Vehicle: MPS3 mkI aero
_________________ Mazda MPS 3 Aero (2008) MK1 BNR3 (fitted 56,000 Miles) Corksport HPFP Cobb AP V3 Corksport Tmic HTP 3" Full Intake (fitted 56,000 Miles) Cobb 3-Port Boost Control Solenoid 235/40/18,Eagle F1 Winter/ Eagle F1 245/40/18 (Summer) mazdaspeed Ariel BC Coilovers Removed the splash guard and resonator box Febi Bilstein Prokit Rear Drop Links Short Shift Plate(Spamface) CFM Rear Motor Mount (9 PEGS) JBR Pass Motor Mount 80a JBR Trans Motor Mount 88a JBR 125 RARB (Middle setting) Forge V2 BPV Stoptech Drilled Slotted Front/Rear Step colder NGK 6510 0.7mm gap (fitted 56,000 Miles) APT Long Downpipe EGR Delete (fitted 56,000 Miles) Coolant bypass RX8 Alloys 3Bar Map Sensor and Harness (fitted 56,000 Miles) Banjo Bolt Motul GEAR 300 LS 75W-90 Fully Synthetic Car Limited Slip Differential Oil(Changed@59,292) Shell Helix Ultra 5W-40 Fully Synthetic Engine Oil ( Changed every 6/7000 miles) MOTS DONE@ Ambleside Motors
BanzaiMike
Post subject: Re: Hi! Posted: Thu May 28, 2015 9:43 pm |
Has thanked: 3 times
Been thanked: 26 times
Hi and Welcome to the Family
Post subject: Re: Hi! Posted: Fri May 29, 2015 8:38 am |
Test Drives Unltd
Post subject: Re: Hi! Posted: Tue Jun 02, 2015 12:05 pm |
b_rutter
Post subject: Re: Hi! Posted: Sat Jun 06, 2015 5:56 pm |
Apologies for how long it's took for a pic, had a few things to get done. Wheel refurb & SRI first on the agenda.
