Page 1 of 1 [ 13 posts ]
 Post subject: Hi All
 Post Posted: Wed Feb 18, 2015 10:19 pm
My name is Artur and I'm Finally a member of the best car forum :mpsoc: :mpsoc:
I live in Devon, and I'm proud owner of mk1 3 MPs in the faster colour :clap:
Haven't done much modding yet, apart from 2nd decat & tip/sri , Cobb an Big J-tune :-P
Hope to meet you lot in person soon:-) :-) :-)
 Post subject: Re: Hi All
 Post Posted: Wed Feb 18, 2015 10:29 pm
About time !!! :D :welcome: to :mpsoc:
 Post Posted: Wed Feb 18, 2015 10:34 pm
:welcome: to :mpsoc: :thumbs:
 Post Posted: Wed Feb 18, 2015 11:11 pm
Welcome to the :mpsoc: Artur.
Good to see you've joined the forum :)
 Post Posted: Wed Feb 18, 2015 11:26 pm
Bhp: 387
lbf·ft: 366
:welcome: to :mpsoc: :)
 Post Posted: Thu Feb 19, 2015 6:41 pm
You must of bought a red one then :D , :welcome: along :thumbs:
 Post Posted: Thu Feb 19, 2015 6:53 pm
Bhp: 294
lbf·ft: 324
true red mk1 3MPS, Hypertech tune, Corksport SRI+TIP, Resonator and 2nd Cat removed, Powerflow custom exhaust, Turbosmart BPV, J-Speed short shift plate, Lowered 40mm H&R springs, Gloss black RX-8 alloys, Mazdaspeed stubby carbon Ariel, XCarlink.
 Post Posted: Thu Feb 19, 2015 7:38 pm
Everyone knows that blacks the fastest colour!
 Post Posted: Fri Feb 20, 2015 5:45 pm
lbf·ft: 322
Welcome to MPSOC. :-)
I'm sure silver is the fastest colour.
 Post Posted: Sun Feb 22, 2015 10:45 pm
Has thanked: 16 times
lbf·ft: 340
Yup Drew, you're spot on ;)
Current Mods :: K&N Typhoon SRI :: Corksport TIP :: Powerflow 2nd Decat :: Forge V1 BPV :: ASI TMIC :: Cobb 3-Port :: VibraTechnics REM :: Koni STR.Ts (Rear) :: Rainsport 3s ::Image (J-Tune In Progress)
Selling up :( ::
 Post Posted: Tue Jun 02, 2015 12:32 pm
 Post Posted: Tue Jun 02, 2015 9:45 pm
Hi and welcome to the forums :mpsoc:
 Post Posted: Wed Jun 03, 2015 1:44 am
Hi and welcome To the forum
