max_db
Post subject: Hi Posted: Sun Feb 01, 2015 10:27 pm |
Joined: Sun Feb 01, 2015 10:22 pm Posts: 149 Location: Bexhill Vehicle: MPS3 mkI aero
Been thanked: 3 times
Hi, My names Max and I'm currently on the look out for a Mazda 3 MPS. I thought I would read up on here some stuff about them. Hopefully I will be looking at a nice low mileage one next week so I'm sure I will be bugging you all with questions
Post subject: Re: Hi Posted: Sun Feb 01, 2015 11:05 pm |
Warm  Max Which of the 3's are you after?
max_db
Post subject: Re: Hi Posted: Sun Feb 01, 2015 11:28 pm |
Hi, It's a MK1 on a 2008 plate. I'm looking at mods already - I'm terrible like that!!
Beds_MPS
Post subject: Re: Hi Posted: Mon Feb 02, 2015 8:00 am |
Joined: Sat Jun 30, 2012 9:20 pm Posts: 3039 Location: Beds Vehicle: MPS3 mkI
Has thanked: 25 times
Been thanked: 122 times
Hi Max. Welcome to MPSOC. There's a buyers guide here somewhere if you do a search. All of the major things to check are in there.
Sent from my XT1032 using Tapatalk
_________________ Used to have : 2008 MK1 3MPS Cosmic Blue -  J-Tuned, stainless steel dials, eBay TIP, Sure SSP, Sure Anchors, K&N Replacement, Drilled Airbox, LED side lights, LED interior lights, LED reverse light, MTEC drilled discs, Yellow Stuff pads, NGK LTR7IX-11, EGR block off. Now: 2005 Corolla T-Sport
ShaunyG
Post subject: Re: Hi Posted: Mon Feb 02, 2015 8:20 am |
Joined: Mon Jan 02, 2012 5:15 pm Posts: 4205 Location: Sheffield Vehicle: other
Has thanked: 2 times
Been thanked: 13 times
_________________ Mazda 3 MPS Crystal White Pearl Mk2 - Stock
Mr. T
Post subject: Re: Hi Posted: Mon Feb 02, 2015 9:25 am |
SilverSport
Post subject: Re: Hi Posted: Mon Feb 02, 2015 9:59 am |
Joined: Thu Feb 27, 2014 3:56 pm Posts: 665 Vehicle: other
Been thanked: 15 times
Gav1888
Post subject: Re: Hi Posted: Mon Feb 02, 2015 10:15 am |
Has thanked: 56 times
Been thanked: 28 times
DrewMPS
Post subject: Re: Hi Posted: Mon Feb 02, 2015 11:50 am |
Joined: Sat Dec 28, 2013 3:25 pm Posts: 158 Location: Lancashire Vehicle: MPS3 mkI aero
lbf·ft: 322
Post subject: Re: Hi Posted: Mon Feb 02, 2015 12:29 pm |
 along
Kenny
Post subject: Re: Hi Posted: Wed Feb 04, 2015 9:49 pm |
Been thanked: 11 times
max_db
Post subject: Re: Hi Posted: Sun Feb 08, 2015 6:33 pm |
Well here it is:  It's a completely standard MK1 with the aero kit. It has just under 30k on the clock so will make a nice long term project. Please note progress will be slightly slow due to me having to do some more work on the house :( I plan on having this as a semi sleeper. Potential plans: Cosmetic:- - Remove the MPS badges and the window stickers the last owner put in - Possible rear de bage and rear wiper removal - Get the small stone dents in the roof taken out - Get the rear sub frame thing re-sprayed or powercoated as showing signs of surface rust - Get some see through rust protector on the arches/bonnet Handling:- - Change the wheels to either 17's and put some bigger tyres on or get some RX8 alloys - Get the softer BBR GTI springs as the ride is a little harsh Performance:- - Get a better turbo as the standard K04's appear to have a habit oil seals braking - High pressure fuel pump - Some sort of air filter - Sports cat's for MOT purposes - Remap like a Cobb or similar - Forged engine/pistons depending on the money It's my first car with a petrol turbo engine so still learning about these things
~Divine~Wind~
Post subject: Re: Hi Posted: Tue Feb 17, 2015 7:37 pm |
Joined: Fri Sep 06, 2013 7:45 pm Posts: 2813 Location: North-East, Newcastle Vehicle: MPS6
Has thanked: 5 times
Been thanked: 136 times
Test Drives Unltd
Post subject: Re: Hi Posted: Tue Feb 17, 2015 10:04 pm |
Joined: Tue Jan 11, 2011 10:48 pm Posts: 1579 Location: West Sussex Vehicle: Toyota
max_db
Post subject: Re: Hi Posted: Wed Feb 18, 2015 1:51 pm |
It's a 2008 model - I'll get some better pics up sometime
