Mark.DM
Post subject: Finally got one Posted: Sun Feb 01, 2015 6:06 pm |
Joined: Thu Jan 29, 2015 2:26 pm Posts: 34 Location: Nottinghamshire, England Vehicle: MPS6
Hi guys, So after owning a Mitsubishi galant V6 for a while iv had my eye on the MPS and knew it had to be my next car. Well yesterday I brought one. Haven't got any pics yet but its fairly standard looking apart from it has powder coated standard wheels and its grey. It does have some performance mods already on it. Induction, BOV and exhaust system which I know is not to everyone's taste. It seems in good order, all 4 tyres are new, no blue smoke or funny noises and a years MOT. The bad bit it it doesn't have any service history So I am going to do all the fluids to be safe. Im going to get tax and insuranse sorted tomorrow so I hant had chance to take it for a proper drive other then the test drive at the dealer and a sneaky round the block. Still got to get used to the clutch which I know are a bit on or off. Il keep you up dated and pics to follow
Post subject: Re: Finally got one Posted: Sun Feb 01, 2015 6:38 pm |
 What MPS is it? Take that BOV off , recirc valve is what's needed on these
Gav1888
Post subject: Re: Finally got one Posted: Sun Feb 01, 2015 6:59 pm |
Has thanked: 56 times
Been thanked: 28 times
 to As kenny said above about recirc....will run too rich with BOV.. Nip into your local mazda dealer they might have digital record of service...that's the way mazda do it now...will prob need your VIN number ... Update your profile and
Post subject: Re: Finally got one Posted: Sun Feb 01, 2015 7:15 pm |
 along
Mr. T
Post subject: Re: Finally got one Posted: Sun Feb 01, 2015 9:35 pm |
 to the Mazda  maaaaaaaatey Sent from Sony Xperia Z Ultra using Tapatalk
SilverSport
Post subject: Re: Finally got one Posted: Sun Feb 01, 2015 10:25 pm |
Joined: Thu Feb 27, 2014 3:56 pm Posts: 665 Vehicle: other
Been thanked: 15 times
Welcome to the  Which MPS have you gone for? As mentioned above, pop in to your local Mazda Dealer, give them your reg. plate and they'll be able to give you your service record (assuming they have it on their DSR system)
Beds_MPS
Post subject: Re: Finally got one Posted: Mon Feb 02, 2015 8:01 am |
Joined: Sat Jun 30, 2012 9:20 pm Posts: 3039 Location: Beds Vehicle: MPS3 mkI
Has thanked: 25 times
Been thanked: 122 times
Hi and welcome to MPSOC.
Sent from my XT1032 using Tapatalk
_________________ Used to have : 2008 MK1 3MPS Cosmic Blue -  J-Tuned, stainless steel dials, eBay TIP, Sure SSP, Sure Anchors, K&N Replacement, Drilled Airbox, LED side lights, LED interior lights, LED reverse light, MTEC drilled discs, Yellow Stuff pads, NGK LTR7IX-11, EGR block off. Now: 2005 Corolla T-Sport
ShaunyG
Post subject: Re: Finally got one Posted: Mon Feb 02, 2015 8:17 am |
Joined: Mon Jan 02, 2012 5:15 pm Posts: 4205 Location: Sheffield Vehicle: other
Has thanked: 2 times
Been thanked: 13 times
_________________ Mazda 3 MPS Crystal White Pearl Mk2 - Stock
DrewMPS
Post subject: Re: Finally got one Posted: Mon Feb 02, 2015 11:50 am |
Joined: Sat Dec 28, 2013 3:25 pm Posts: 158 Location: Lancashire Vehicle: MPS3 mkI aero
lbf·ft: 322
gronow89
Post subject: Re: Finally got one Posted: Mon Feb 02, 2015 12:44 pm |
Joined: Tue May 08, 2012 8:40 pm Posts: 4176 Location: bridgend, south wales Vehicle: MPS3 mkI aero
Has thanked: 19 times
Been thanked: 46 times
Welcome bud
_________________ Wisseco pistons, Manley h beam rods, Arp main stud kit, Arp head stud kit, Fidanza ali flywheel, Cpe Balance shaft delete, Damond Egr delete kit, Inlet manifold butterfly delete, Coolent bypass, Cpe injector seals, Htp 3" intake, Aem cone filter, Bnr stage4 turbocharger, Grimspeed 3port bcs, Bosch 3bar map sensor, Ngk 1 step colder, 3" catless downpipe, 2nd decat delete, Cxracing custom pipes, Treadstone tr8 fmic, Sure short shift kit, Mme solid shifter bushes, Custom 676g gear knob, Xspower manifold, Devils own meth injection, Forge recirc valve, Autotech hpfp, Jbr thermal intake gasket, Hel stainless lines, Rear defuser, jbr air dam, Mk2 alloys, Versatuner.
Mark.DM
Post subject: Re: Finally got one Posted: Mon Feb 02, 2015 3:52 pm |
Thank you for you warm welcome. I should have said, its a 6. Not sure what mk but its an 06 plate. I have noticed one slight problem, which could be related to it running rich with its bov which you have mentioned is not ideal. When I pull up to stop and depress the clutch, like at a junction or lights etc, the cars revs drop and it feels like it is going to stall for a second. Is this the BOV thats causing this or can I just adjust the idle control valve?
Post subject: Re: Finally got one Posted: Mon Feb 02, 2015 5:20 pm |
There were only 2 versions of the 6: One fitted with sat nav and one without. What mileage is on yours and did you need to travel to get it?
My guess is that yours is an early 06 model with the snatchy clutch. Don`t despair, there is a free adjustment which lowers the pick up point on the clutch pedal. It doesn`t cure the snatch but it does make it a lot more comfortable.
Strongly recommend you sign up as a member. The best £20 you will spend especially as a newbie to the MPS.
Mark.DM
Post subject: Re: Finally got one Posted: Mon Feb 02, 2015 11:35 pm |
Mine doesnt have a sat nav, it has 85k on the clock. I traveled to Manchester to get it. Yer the clutch has two settings, on or off lol So I will look into that fix. I will be paying up soon, Iv been a member of the club for my previous car and they are worth the money, I think I made it back a few times over on my car insurance club discount, plus all the knowledge is priceless.
Kenny
Post subject: Re: Finally got one Posted: Wed Feb 04, 2015 9:51 pm |
Been thanked: 11 times
ffz
Post subject: Re: Finally got one Posted: Wed Feb 04, 2015 10:59 pm |
Joined: Mon May 27, 2013 7:01 pm Posts: 2940 Location: Doncaster Vehicle: MPS3 mkII
Has thanked: 6 times
Been thanked: 8 times
Welcome!
Sounds like BOV or possible dirty MAF/dodgy O2 sensor. Could also be a vac leak.
_________________ I got some mods...
