Dizzle
Post subject: A beep at high speed/high revs.... What is it? Posted: Sat Jan 31, 2015 4:47 pm |
Joined: Sat Jan 10, 2015 2:47 pm Posts: 19 Location: Buckinghamshire Vehicle: MPS3 mkI aero
Bhp: 292
Hi guys, Another newbie owner of mk 1 3. Today while battering and Gti  there was a beep while I was doing about 120 and 5.5-6 revs. Is this normal, as haven't heard it before. Did freak me out a little at that speed!! Cheers D
Gav1888
Post subject: Re: A beep at high speed/high revs.... What is it? Posted: Sat Jan 31, 2015 4:52 pm |
Has thanked: 56 times
Been thanked: 28 times
Not sure bout mk1 but on mk2 u can set a speed limit and it beeps wen u hit it....
Post subject: Re: A beep at high speed/high revs.... What is it? Posted: Sat Jan 31, 2015 4:55 pm |
Is that OEM software or modded?
Gav1888
Post subject: Re: A beep at high speed/high revs.... What is it? Posted: Sat Jan 31, 2015 5:07 pm |
foxy wrote: Is that OEM software or modded? OEM
Jack95
Post subject: Re: A beep at high speed/high revs.... What is it? Posted: Sat Jan 31, 2015 5:44 pm |
Joined: Sun Jun 08, 2014 2:49 pm Posts: 149 Location: Stirling Scotland Vehicle: MPS3 mkII
Just go onto preferences on the screen and turn it off.
EliotG
Post subject: Re: A beep at high speed/high revs.... What is it? Posted: Sat Jan 31, 2015 5:49 pm |
Joined: Wed May 01, 2013 10:36 am Posts: 566 Vehicle: MPS3 mkI aero
Been thanked: 9 times
I've never seen this option on my mk1...
_________________ Mods: JBR SRI/TIP || JBR Shifter Bushings || SF SSP || Custom 2nd Decat + Silencer || Forge v2 BPV || Cobb v2 || J-Tune || Bilstein B8
Jack95
Post subject: Re: A beep at high speed/high revs.... What is it? Posted: Sat Jan 31, 2015 6:01 pm |
Sorry never read that it was a mk1
Beds_MPS
Post subject: Re: A beep at high speed/high revs.... What is it? Posted: Sat Jan 31, 2015 6:07 pm |
Joined: Sat Jun 30, 2012 9:20 pm Posts: 3039 Location: Beds Vehicle: MPS3 mkI
Has thanked: 25 times
Been thanked: 122 times
I've never heard a beep in my mk1
Sent from my XT1032 using Tapatalk
_________________ Used to have : 2008 MK1 3MPS Cosmic Blue -  J-Tuned, stainless steel dials, eBay TIP, Sure SSP, Sure Anchors, K&N Replacement, Drilled Airbox, LED side lights, LED interior lights, LED reverse light, MTEC drilled discs, Yellow Stuff pads, NGK LTR7IX-11, EGR block off. Now: 2005 Corolla T-Sport
cfcjre
Post subject: Re: A beep at high speed/high revs.... What is it? Posted: Sat Jan 31, 2015 6:08 pm |
Joined: Tue Sep 16, 2014 3:21 pm Posts: 307 Location: Newcastle-under-Lyme Vehicle: MPS3 mkI aero
Bhp: 294
lbf·ft: 324
I've never heard mine beep
_________________ true red mk1 3MPS, Hypertech tune, Corksport SRI+TIP, Resonator and 2nd Cat removed, Powerflow custom exhaust, Turbosmart BPV, J-Speed short shift plate, Lowered 40mm H&R springs, Gloss black RX-8 alloys, Mazdaspeed stubby carbon Ariel, XCarlink.
MartinMcHattie
Post subject: Re: A beep at high speed/high revs.... What is it? Posted: Sat Jan 31, 2015 7:01 pm |
Joined: Sun Jul 28, 2013 6:50 pm Posts: 618 Location: Aberdeen, Scotland Vehicle: MPS6
Been thanked: 4 times
Been to 150 in my 6 and never heard a beep either
Sent from my iPhone using Tapatalk
_________________ BNR S3, HTP 3" intake, 200cell catted Downpipe, ETS TMIC, Autotech HPFP internals, Forge v2 Recirc, Remus CatBack Exhaust, Port/Polish Manifold and TIG, Throttle Body Coolant Bypass, SURE REM, Turbine Tech Front Diff Mount, CPE rear diff brace, Whiteline RARB, JBR SSP Tuned By JustinUp Next: Rust Removal! OCC, Handling of all kinds!:thumbs:*A car is just Fast enough when you stand in front of it in the morning and are afraid to unlock it*
Mr. T
Post subject: Re: A beep at high speed/high revs.... What is it? Posted: Sat Jan 31, 2015 7:38 pm |
Never been over 100 mph [DISAPPOINTED FACE]
MartinMcHattie
Post subject: Re: A beep at high speed/high revs.... What is it? Posted: Sat Jan 31, 2015 7:48 pm |
Never been over 100? That's poor. You're missing out
Mr. T
Post subject: Re: A beep at high speed/high revs.... What is it? Posted: Sat Jan 31, 2015 7:52 pm |
Don't fancy getting points  Sent from Sony Xperia Z Ultra using Tapatalk
MartinMcHattie
Post subject: Re: A beep at high speed/high revs.... What is it? Posted: Sat Jan 31, 2015 7:53 pm |
Don't get caught. Logging takes you over 100
Gav1888
Post subject: Re: A beep at high speed/high revs.... What is it? Posted: Sat Jan 31, 2015 8:02 pm |
Mr. T wrote: Don't fancy getting points  Sent from Sony Xperia Z Ultra using Tapatalk  So do u never do 40 in a 30????? That will still get u points... I've had mine at 140 but cobb told me I was doing more like 130 Sent from my iPad using Tapatalk
Users browsing this forum: No registered users and 10 guests |
