Page 1 of 2 [ 18 posts ] Go to page 1, 2  Next
 Post subject: newbie with a mk2 3 mps
 Post Posted: Sat Oct 25, 2014 7:19 pm
Hi all,
Chris from Aberdeen here. Just picked up my velocity red mk2 3 mps yesterday and loving it so far. My last couple of cars have been a Octy mk1 vrs and a modded impreza sti. Decided a bit of change would be good so the scooby is up for sale :)
Quick question, ive got a set of team dynamics pro race's with 235 40 18 tyres on my scoob, would these be ok to fit to the mps? They are the perfect offset and pcd, just not sure on the tire width
 Post subject: Re: newbie with a mk2 3 mps
 Post Posted: Sat Oct 25, 2014 7:45 pm
:welcome: to :mpsoc: buddy
Best and fastest colour.....
Pics please
 Post Posted: Sat Oct 25, 2014 7:58 pm
Here you go :D
 Post Posted: Sat Oct 25, 2014 11:48 pm
:welcome: along! How does the mps compare to the Subaru?
 Post Posted: Sun Oct 26, 2014 9:41 am
:welcome: along :thumbs:
 Post Posted: Sun Oct 26, 2014 9:44 am
There's and Aberdeen meet coming up if you fancy it!
viewtopic.php?f=121&t=20331
 Post Posted: Sun Oct 26, 2014 10:15 am
Bhp: 281
 Post Posted: Sun Oct 26, 2014 10:54 am
welcome to the forum dude :)
I'd expect those tyres to be fine, check for rubbing tho
 Post Posted: Sun Oct 26, 2014 11:10 am
Cheers all. It's a wee bit different to the scoob :) handling wise the scoob was better but that was on bilstein coilies and whiteline goodies. I'll probably go for the bilstein struts and eibach springs on the mps though. Power wise it's staying standard :blush: fell down that trap with the scooby
I'll try the td's on later on. It's come with hedge hunters on the front wheels, fortunately I've got 4 new 235 40 18 michelin ps2s living in my flat so hence the question
 Post Posted: Tue Oct 28, 2014 3:02 pm
Welcome to the forum. Good to see another mk2 on here :thumbs:
 Post Posted: Tue Oct 28, 2014 3:52 pm
:welcome: to the :mpsoc:
 Post Posted: Tue Oct 28, 2014 5:34 pm
Hello and welcome to the family
 Post Posted: Tue Oct 28, 2014 5:40 pm
Has thanked: 6 times
Screen shot the 'staying standard power'. It isn't going to happen lol
Also, definitely the fastest colour ;-)
I got some mods...
 Post Posted: Tue Oct 28, 2014 8:36 pm
Nope it's staying standard power :help: I said that with the scooby and ended up with 400bhp and 440ftlbs. Am planning a track car so the mazda is staying standard.... power wise anyway :D
 Post Posted: Tue Oct 28, 2014 8:47 pm
Wanna bet :ihih: :ihih:
