Page 1 of 1 [ 5 posts ]
 Post subject: Hi, totally new to Mazda mps check list for buying
 Post Posted: Fri Aug 22, 2014 9:24 pm
Hey guys
I'm looking at a 2010 Mazda 3 mps fsh with about 45k on it.
Problem is I don't know much about them, from reading
Check turbo, timing chain, rear shocks
When is the chain due for service? Any other hidden issues
Cheers jake
 Post subject: Re: Hi, totally new to Mazda mps check list for buying
 Post Posted: Fri Aug 22, 2014 11:11 pm
Welcome to the forum.
The chain doesn't get serviced bud. It's supposed to last a life time.
 Post Posted: Sat Aug 23, 2014 7:38 am
:welcome: to :mpsoc:
 Post Posted: Sat Aug 23, 2014 7:46 am
Hi bud. Welcome along. This might help but is for a 6.
Check for smoke from exhaust when cold.
Check for smoke after 10 minute idle. I think crank case pressure builds on Idle putting pressure on turbo seals cashing smoke if they're leaking.
Chain is lifetime part but early ones were Shit, check for chain slap/noises as thwyre prone to failure.
Rust on early 6's. Think the 3 was ok.
Aircon susceptible to failure - holes in compressors can leaky hoses.
History is useful. After 2007 you won't get a book iirc as it's all electronic. Just call Mazda with the vin (not reg. Has to be vin) and they'll look it up.
Driver bolster wear.
But I'm no expert. Use the search button bud!
 Post Posted: Tue Aug 26, 2014 3:50 pm
