Page 1 of 3 [ 44 posts ] Go to page 1, 2, 3  Next
 Post subject: Helloooo
 Post Posted: Fri Jul 04, 2014 11:13 pm
Hi There,
New forum user here, im interested in buying an 3MPS or 6MPS, and getting rid of my mondeo st.
Can someone post up links to a buyers guide for the 3 & 6 MPS. i can find one :(
thank you :)
 Post subject: Re: Helloooo
 Post Posted: Sat Jul 05, 2014 7:16 am
Has thanked: 17 times
Bhp: 279
lbf·ft: 301
Alright mate. Welcome along. Have a quick search and you'll get some good tips. Main issues to watch out for are VVT (listen for chain slap on cold start) and smokey turbo (let it idle for 10 mins and check for blue smoke).
Where are you based? Might be able to find a friendly member close by that can give you a run in a 3 and/or 6. 6's are a bit cheaper but probably a bit easier to find a good example of a 3.
Titanium Grey 6MPS, Autotech fuel pump internals, Custom 3" cat-back, H&R springs, Forge BPV, AWR REM, Corksport SRI & TIP, Cobb V3 + J-Tune
 Post Posted: Sat Jul 05, 2014 7:44 am
You'll be able to find one, just not normally a fast process lol and normally involves a fair trek to get it.
Read thru the threads in the welcome section loads of helpful tops on buying.
Oh and please don't be pulled in by these people asking daft money as the car has low miles, I saw an add asking I think it was 10k for a facelift mk1 because it only had 9k on the clock lol
Generally speaking 6s are a fair chunk cheaper than a comparable 3, can be in the lower tax bracket of 265.
All mk1 3s are in the high tax bracket 490, available as aero and standard, aero adds spoiler, different wing mirrors and uprated suspension.
Mk2s from what I've seen are the lower tax of 265 and are absolutely stuffed with toys, alto I did read that at one point there was a batch without sat nav.
For facelifts I'm not sure if they can fall into either tax bracket or are always the higher one.
The three different versions of the 3 all have a slightly different interior trim, whereas the 6 only had one option... Full leather
 Post Posted: Sat Jul 05, 2014 9:03 am
All mk1's are in the higher tax bracket.
:welcome: to the :mpsoc: btw :thumbs:
 Post Posted: Sat Jul 05, 2014 9:51 am
The road tax change over date was 23/03/06. After that date any 6 will be in the higher band. All Mk1 3`s are in the higher band.
 Post Posted: Sat Jul 05, 2014 10:44 am
Bhp: 148
lbf·ft: 138
Hi and welcome.
 Post Posted: Sat Jul 05, 2014 12:02 pm
what differances are there between the mk1 2 & 3 3mps? i'm struggling to identify them.
Also what years, to and from, are the 3 and 6 in the lower tax bracket?
 Post Posted: Sat Jul 05, 2014 1:42 pm
You can get some 6s alto very few registered before the tax went up, see the date above, as long add they were regulated before that you'll get lower tax bracket.
All mk1 3s including facelifts are high tax bracket
All Mk2 3s are lower tax bracket, Mk 2s have the bonnet scoop
 Post Posted: Sat Jul 05, 2014 4:10 pm
Hello and welcome!
 Post Posted: Sat Jul 05, 2014 6:07 pm
Wouldn't get to hung up on the road tax , it will cost far more if the cars not been looked after. I would say the couple of hundred quid will soon be put in the tank anyway. As said before be prepared to travel do your homework check the forum for what to look out for. Also if you do locate one miles away you can normally find somebody on here to check it out for you and save a wasted trip. Good luck.
CPe REM , Whiteline RARB , Sure Juggernaut and Dreadnaught, Bilstein shocks H&R springs, CS DP, TMIC , Fuel pump, BPV, Stage II Intake, Top struts front and rear, Jetex cat back, EGR Delete, SS brake lines, DBA 4000 XS to be fitted. Versatune By Justin... ongoing.
 Post Posted: Sat Jul 05, 2014 6:17 pm
 Post Posted: Sat Jul 05, 2014 9:40 pm
Welcome along mate. But after a mondeo if you need the space get a 6. They never should have stopped making them. Amazing car.
Current mods
Sure short shift plate/jbr rem/k&n air filter/
2nd decat/mtec brake discs/yellow stuff pads all round/hel braided brake lines/dot 5.1 fluid/millers oils throughout/corksport diff and gearbox mounts RX8 alloys black with uniroyal rain sport 3/ fibreglass front grill in black. Gfb response with whistle trumpet/ Interior, boot and footwell led kit. Cobb v3 ordered from new age autos.
Future mods::: Exhaust, intake and cs hpfp internals.
 Post Posted: Sat Jul 05, 2014 10:16 pm
:welcome: along to :mpsoc: mate :thumbs:
 Post Posted: Sat Jul 05, 2014 11:08 pm
unless i'm blind but i can see a thread about what to look for. i'm wanting a 3 more than a 6 tbh.
just out of curiosity, can you put a tow bar on a 3?
 Post Posted: Sun Jul 06, 2014 12:24 am
is this a mk1 3mps?
http://www.ebay.co.uk/itm/281373395959? ... 1423.l2649
Users browsing this forum: Google [Bot] and 2 guests
