Page 1 of 1 [ 7 posts ]
 Post subject: Soon to be 6MPS owner from south africa
 Post Posted: Fri Apr 11, 2014 4:50 pm
Hi all,
Im about to pull the trigger on a 08 MPS with 80 000 km on the clock, fsh, no major repairs has been done on the car and it never gave any problems, pads + discs were replaced 10 000km ago, owned by mature older family man - still bone stock.
I have been a bike (R1) owner for the past 5 or so years but becoming a dad in october so wifey said it has to go and after somesearching the 6 seems like the ideal candidate.
I guess my questions are:
1. Anything specific i should look for on the car before i do the final paperwork
2. Any type of common problems that they have or that i should look for after taking ownership
3. Basic upgrades to give it some extra puff while still keeping it reliable (will be used as main family car on holidays and longer trips)
4. Havent tested its bose sound yet - but how would a proper amp installation compliment the standard setup.
Like i said , im mainly a bike nut so very unfamilliar with all the jargon on the forum...lol
 Post subject: Re: Soon to be 6MPS owner from south africa
 Post Posted: Sat Apr 12, 2014 2:12 pm
Has thanked: 14 times
Been thanked: 18 times
Have a read of this
viewforum.php?f=47
All available if you go through the Forum and have a good look around the site.
MPS 6 are a good car. Get it bought :thumbs:
Tuned with Image
Alcon 6 pot Brake Calipers with 365mm Discs, Cosmis S1 18x9.5 inch alloys and 265/35/18 tyres
Treadstone Front Mount Intercooler Kit. TR1035 core, clamps with piping, and a crash bar!
CorkSport Power Series II SRI, Blitz Bypass Valve
Cobra Single Exit Exhaust and Decat
CorkSport Upper Control Arms adjustability from -0.2 degrees to -2.0 degrees for added and improved control, spherical bearings replace the soft rubber bushings used in OEM and arms for more precise suspension settings
Corksport Rear Camber Arms +/- 5 degrees of camber adjustment
AWR Engine Mount Set
Turbine Tech forward Differential Mount Brace
CPE xFlex™ Rear Differential Mount
Whiteline Upgraded Anti Roll Bar
Bilstein B12 Pro Suspesion Kit
RX8 R3 Recaro's, Retrimmed RX8 R3 Steering wheel in Leather and Alcantara with Red stitching. James Barone Racing - Short Shift Kit and JBR Heavy Gear Knob.
Evo X rear Spoiler LED rear lights
VersaTuner map
 Post Posted: Sat Apr 12, 2014 3:34 pm
 Post Posted: Mon Apr 14, 2014 1:09 am
Vehicle: Scooby
Bhp: 276
lbf·ft: 283
welcome to the site always nice to see another 6 owner ill answer a couple of your questions for you
3)if you want it family orientated id go with upgrading to a jbr turbo intake pipe and short ram intake system,a 2nd decat pipe,and either a cobb tuner or a versa tuner these should help boost you to around 270-280bhp mark,a set of lowering springs h&r or eibach pro kit are the choice on here along with bilstein b8 shocks and upgrade the rear anti roll bar,and an upgraded rear engine mount
4)if you intend running an external amp you will need to change most components of the sound system as there is no pre outs to run external subs but to be honest the standard bose system is pretty decent
I hope this helps you out a bit dude
3"decat downpipe, 3"2nd decat, 3"catback with angled 4 1/2" t/p,modded airbox with green panelfilter, bailey motorsports dump valve
 Post Posted: Thu May 01, 2014 9:10 pm
 Post Posted: Thu May 01, 2014 10:16 pm
Hi and welcome to the forum
 Post Posted: Fri May 02, 2014 4:18 am
Hello and welcome to :mpsoc: Did you manage to get the car? if so :wwp: :wwp:
