Page 1 of 1 [ 13 posts ]
 Post subject: Had my MPS for a few months
 Post Posted: Sat Jul 03, 2010 12:08 pm
Guest
Hi All had mine since December but just found the site, nice to see so many MPS owners out there.
I love the car
a few questions for you all
how long do the standard tyres last Potenzas? just changed a set at 8k
does anyone see any better performance from better grade fuel ie the higher ron grade?
Where is the next meet?
 Post subject: Re: Had my MPS for a few months
 Post Posted: Sat Jul 03, 2010 12:17 pm
I love the car
Depends on your hooligan factor and how soft the rubber is. I'd expect the Potenzas to last 6-12K on the front for mixed driving.
You need to run on BP 97RON super minimum, preferably Shell V Power 99RON. If you don't the ignition will be retarded and the fuelling adjusted and you'll loose a chunk of power.
Today at Ace Cafe
Tommorow at Japshow
Where abouts are you?
 Post Posted: Sat Jul 03, 2010 3:42 pm
:yeahthat:
 Post Posted: Sat Jul 03, 2010 6:32 pm
Bhp: 475
lbf·ft: 505
Just make sure you rotate them every 4-6k miles and they're going to be fine. I sold mine after I used them like 12k miles and they were work 1.5mm our of 8.
2008 Cosmic Blue Mazda 3 MPS
SU TMIC, CS Inserts/OEM RMM, CS CAI Box+Cobb SRI+CP-E BT TIP, ITV22, TurboSmart BPV, UR Catted DP + res. TP, GS EBCS, GTX3071R, Bosch 3BAR, StratiVersaTuned
Bilstein B14PSS, SSR Type-F 7.5x18 Wheels + Michelin PSS 225/40/ZR18 US Spec
 Post Posted: Sat Jul 03, 2010 6:58 pm
My fronts have worn 4mm in 6000 miles. Perhaps i need to rethink my driving style! :lol:
 Post Posted: Sat Jul 03, 2010 7:19 pm
Nah. Must be driving too gently. Should be 4mm in 5000 miles.
 Post Posted: Sat Jul 03, 2010 7:23 pm
Bhp: 475
lbf·ft: 505
what about the rear tires? You should really rotate them, usually the rear tires wear less than the front tires.
 Post Posted: Sat Jul 03, 2010 7:33 pm
hello and :welcome:
 Post Posted: Sat Jul 03, 2010 7:38 pm
 Post Posted: Sat Jul 03, 2010 8:17 pm
If you do that you end up changing all 4 tyres at the same time rather than in pairs.
 Post Posted: Sun Jul 04, 2010 8:18 pm
Welcome,
Are you from Mirfield, Near Huddersfield by any chance?
 Post Posted: Sun Jul 04, 2010 10:31 pm
 Post Posted: Sun Jul 04, 2010 10:53 pm
