Page 1 of 2 [ 21 posts ] Go to page 1, 2  Next
 Post subject: Hi
 Post Posted: Fri Oct 26, 2012 9:14 pm
Hi all
Need help, im looking into buying a Mps 3 Mk1 :D
What do i need to look out for in and how easy is tuning?
G
 Post subject: Re: Hi
 Post Posted: Fri Oct 26, 2012 9:19 pm
Hi , there is one in the for sale section at the min
 Post Posted: Fri Oct 26, 2012 9:35 pm
yea theres a good one but for salein the for sale thread but you need to be paid up to see it i think. and theres a few tings to look out for. one is for noisey vvt actuator not to coman but you need to listen down the left side of the engine for a loud rattle. after a run do a long idel test to check the turbo seals. at least 10 mins once warm. the rest is just check general condition.
as for tuning is not to bad anymore, depends what you looking for. 320bhp is easy.
 Post Posted: Fri Oct 26, 2012 10:51 pm
:welcome: to the forum.
 Post Posted: Fri Oct 26, 2012 11:16 pm
 Post Posted: Sat Oct 27, 2012 12:22 am
Welcome aboard mate.
 Post Posted: Sat Oct 27, 2012 6:40 pm
 Post Posted: Sat Oct 27, 2012 7:00 pm
Been thanked: 6 times
Bhp: 266
lbf·ft: 286
Welcome aboard! :thumbs:
MK1 3MPS aero K&N Panel filter, Corksport TIP, MME solid shifter bushes, Poly ARB's all round and MPS mud Flaps. Thats all folks!
1327 BIK lumpif
 Post Posted: Sat Oct 27, 2012 7:04 pm
 Post Posted: Sun Oct 28, 2012 8:55 am
Hello and Welcome.
Just check for VVT rattle Chain rattle from the LHS of the engine) and Smokey Turbo (let the car idle for 10/15mins, if theres a lot of white smoke, most likely needs a new turbo as the turbo seals will be shot).
I would say its quite easy to get close to 300hp without the need of a map with a few bolt on mods, SRI/TIP, Decat etc If you want over 300hp, then you'll be needing a map either a remap from the likes of totalmps, bbr, RSTuning or diy via Versatuner or COBB AP. You'll need new pump internals over 300hp as well just to be safe :thumbs:
 Post Posted: Sun Oct 28, 2012 12:09 pm
I thought what Shaun says was true too about the HPFP, until Justin (DJJUT) told me off, I quote….
"Wrong...... fuel pump internal requirements are related to how boost is tuned and how aggresively it comes in. The dips in fuel pressure mainly occur in spool up when going WOT or between gear changes"
 Post Posted: Sun Oct 28, 2012 12:18 pm
learn summat new every day :thumbs:
 Post Posted: Sun Oct 28, 2012 12:21 pm
So did I, yesterday it was too, on Facebook, thought I was advising someone, turns out not, Justin stepped in and gave me what for, lol : eek2 : :D :D
 Post Posted: Sun Oct 28, 2012 12:26 pm
:welcome: Welcome aboard Mate.
Corksport intake & Turbo inlet pipe, 2nd De-Cat, Forge recirculation valve,
Corksport Short shifter kit, Front LED Smoke Reflectors. 4 Front and 4 back parking sensors, 100w xenon front fog bulbs, MTEC 320mm front, 314mm rear Drilled,Grooved Discs EBC RED STUFF PADS. EIBACH PRO-KIT LOWERING SPRINGS
Future Plans: FORGE INTERNALS, bigger turbo upgrade
 Post Posted: Sun Oct 28, 2012 12:54 pm
I didn't mean any harm :lol: Just what I have seen when helping people with their tunes...... :thumbs:
