Page 1 of 2 [ 22 posts ] Go to page 1, 2  Next
 Post subject: New owner
 Post Posted: Mon Sep 03, 2012 8:01 pm
Hi all,
I recently got myself a nice white 3 mps. I really like the car, does anyone have any suggestions of mods i could do.
Thanks mj63
 Post subject: Re: New owner
 Post Posted: Mon Sep 03, 2012 8:03 pm
Been thanked: 209 times
Read on here for half an hour then make a list.
You may need to call your bank in the morning!
Do you want to make the engine more powerful, or the suspension or brakes better, or change the way it looks or improve the sound system?
Edited to add : WELCOME. We are a friendly bunch. Tell us a bit about yourself and your new pride & joy
 Post Posted: Mon Sep 03, 2012 8:11 pm
Bhp: 472
Jus give gunther a call with all your bank details!!
Tuned with Image by Image
 Post Posted: Mon Sep 03, 2012 8:31 pm
Bhp: 387
lbf·ft: 366
What he said ^^^ and :welcome: to the forum :)
 Post Posted: Mon Sep 03, 2012 8:45 pm
Hello and welcome.
 Post Posted: Mon Sep 03, 2012 8:58 pm
Hello & :welcome: :thumbs:
 Post Posted: Mon Sep 03, 2012 9:04 pm
:welcome: aboard :thumbs:
 Post Posted: Mon Sep 03, 2012 9:17 pm
hi and welcome. yes we have lots of ideas on mods you can do.
 Post Posted: Mon Sep 03, 2012 9:22 pm
 Post Posted: Mon Sep 03, 2012 9:38 pm
Indeed, 1st get a mortgage, secondly read this forum for a week, 3rdly spend like hell!! : eek2 : :thumbs:
Advice here from people is A1*, listen to them and you won't go far wrong. :D
 Post Posted: Mon Sep 03, 2012 10:18 pm
Mj63 wrote:
Hi all,
Thanks mj63
The golden rule is not to start with a figure in mind. Start with what you want to achieve from behind the wheel. After all, two cars, both producing 300bhp, might drive completely differently. What matters is how the car feels to you and how driveable it is. It's actually very easy to get 300bhp out of an agressive map on an MPS but that doesn't mean it's a good thing since the MPS engine is all about torque and in-gear performance. It's not about peak power but about grunt. And simply mapping a car for 300bhp means it'll be lean and the power will be way up in the rpm band so you'll be out of the efficiency zone of the K04 turbo and possibly doing damage. No point in having 300bhp available at 6500rpm if your car naturally loses efficiencies over 5000rpm ... which it does.
Get an induction kit because it's cheap and frees up the car somewhat - and it sounds nice too Hold back until someone's guinea-pigged the MOT after removing cats to make choices on the exhaust but as a minimum you might want a 2nd decat since it helps the turbo spool faster and sounds nicer from outside - and again, it's cheap Then if that's all you want to do get it remapped or buy a Hypertech/Versatune and enjoy it
 Post Posted: Mon Sep 03, 2012 10:29 pm
Hello and welcome mate.
 Post Posted: Tue Sep 04, 2012 6:27 am
:welcome: .
 Post Posted: Tue Sep 04, 2012 6:38 am
Bhp: 367
lbf·ft: 417
Mj63 wrote:
Hi all,
Thanks mj63
Hi there, and welcome to the MPS family.
Mazda 6 MPS / GFB BPV / RX-8 8 x 18" Wheels / Bilstein B8 & Eibach Pro-Kit / Stainless Steel Brake Lines / Autoexe Front Strut Bar / SU Rear Brace Bar / SURE Anchors, CounterShift / Ralco RZ STS stage 2 / SURE Dreadnaught & Torq R6 70a / GrimmSpeed EBCS (Interrupt) / 621 g. AGS Shift Knob / CorkSport TMIC / CorkSport Power Series 3" Intake / EBC RedStuff / Disabled EGR / AutoTech HPFP internals / CorkSport catted downpipe / NGK 1 step colder / BNR stage 3 v2
 Post Posted: Tue Sep 04, 2012 6:56 am
:welcome: you've come to the right place to spend money :D
Black MK1 3 MPS Aero - AP Tuned - Now SOLD - but not forgotton :cry:
Showroom Thread
Users browsing this forum: No registered users and 11 guests
