 Post subject: Re: New to Mazda3 mps few q's
 Post Posted: Sun Aug 26, 2012 8:26 am
Has thanked: 19 times
Been thanked: 46 times
To get the driver side rear window working open the door do the window up and keep holding the switch till u hear a click. As for the rest im sure the guys be along to help u out soon
 Post Posted: Sun Aug 26, 2012 8:31 am
the squeeks will most likely be the seats, the inside can be quite squeeky, think it could be washers somewhere on the seat, cant remember exactly where but just remember reading summat on here before.
your will have a aux in in the glove box being an 09 plate :thumbs:
oh and :welcome: to the forum :thumbs:
 Post Posted: Sun Aug 26, 2012 11:03 am
The front window. i would be checking the window channel for clips as it may of had wind deflectors at somepoint and the clip is stopping it going up.
the rear window. Turn your ignition on the hold the window switch on the door its not working on down till you here a click or 10seconds then all the way up untill you hear a click or 10 seconds and it will reset it.
never heard of aircon rattke before. whats the mileage? yours should have the updated vvt unit but i would just lift the bonet and have a listen to the top left of the engine for chain slap or vvt rattle.
as for squeeks, they all squeek. mine has a buzz from the rear view mirror and a random squeek i cant locate. i dont think the harder suspension helps.
 Post Posted: Sun Aug 26, 2012 2:23 pm
[quote="Gavin"]welcome to the forum
The front window. i would be checking the window channel for clips as it may of had wind deflectors at somepoint and the clip is stopping it going up.quote]
good call on the clips :thumbs:
 Post Posted: Sun Aug 26, 2012 9:30 pm
There is a mod you can make for the amp that's in the members section. If your cars stock you need to he changing up at about 5.7k. After this point the stock hpfp drops loads of pressure.
 Post Posted: Tue Aug 28, 2012 7:07 am
Oh yes mate. We can soon empty your bank account. Gust forum for tuning advice. There's a few vids of mine I put up yesterday on the move.
 Post Posted: Tue Aug 28, 2012 7:52 am
whoompthereitgoes wrote:
Ok Thanks Gavin..I will give an update on the window and aircon when sorted incase anyone else had similar..still loving the looks on people who can't believe its shifts so quick! (I bet yours goes some at 348bhp/500nm!!)I think looking at your mods a remap and upgrades might be coming..I somehow I feel this being an expensive site..;)
yeah i joined here intending to stay standard, dint last long and the credit card took a hammering :D
 Post Posted: Tue Aug 28, 2012 8:36 am
Yup expensive indeed :thumbs:
For your seat you may find its the seatbelt, down beside the centre arm rest slightly slacken the bolt on either side which secures your seatbelt holder to the seat. There is a proper fixing kit but the above method should work mate.
 Post Posted: Tue Aug 28, 2012 1:20 pm
Bhp: 280
the bose stereo has some settings that make it louder, give it more bass, i think you access this from the knob on the rhs of the head unit, press that i think and you can dial up the sound (i think thats right)
Sure Aeros SRI Sure Sidewinder TIP and Sure Return. Goodyear Eagle F1 Asymmetric 2's. NGK ILTR6A-8G Spark Plugs.
 Post Posted: Tue Aug 28, 2012 2:59 pm
What year is yours.
 Post Posted: Tue Aug 28, 2012 5:06 pm
the facelift mk1 . there is only 136 in the uk.
 Post Posted: Wed Aug 29, 2012 11:22 am
mk1 2006-2008 mk1 mps non aero- just the standard mps
http://www.autotrader.co.uk/classified/ ... ?logcode=p
mk1 2006-2008 sport aero option pack. ebach springs. diferant spoiler and mirrors.
mk1 2008-2009 facelift. all sport aeros.the same spoiler, mirors and spring but they droped cosmic mica blue in the colour range and added white. uprated piano black trim on the dash and black seats. also had shadow chrome wheels with with needle in the dials instead of orange.
http://www.autotrader.co.uk/search/used ... e-to/11000
thats the 3 variants of the mk1 mps
 Post Posted: Wed Aug 29, 2012 4:10 pm
you have it spot on mate. i didnt realize the white one was a mixed up one but yes there is a few mix and match one kicking about but as a rule what i said is correct.
tbh honest its the first mix and match white one i have seen.
 Post Posted: Thu Aug 30, 2012 6:21 am
Bhp: 472
Never bothered tbh, why would it be any worse than braking on the road?
Tuned with Image by Image
 Post Posted: Thu Aug 30, 2012 7:59 am
having read the above, i kinda clicked and realised that mine has the white dials etc, registered March 08, i always thought mine was too early (registered) to be a rare facelift. so if mine has the piano black interior and the white needles it will be a face lift and 1 of only 136 in the UK?
