BLUNTY
Post subject: Re: Hi Posted: Wed Feb 18, 2015 2:19 pm |
Joined: Sun Feb 13, 2011 1:23 pm Posts: 367 Location: Sunderland Vehicle: MPS3 mkI aero
Been thanked: 15 times
 to you sir
_________________ Mazda MPS 3 Aero (2008) MK1 BNR3 (fitted 56,000 Miles) Corksport HPFP Cobb AP V3 Corksport Tmic HTP 3" Full Intake (fitted 56,000 Miles) Cobb 3-Port Boost Control Solenoid 235/40/18,Eagle F1 Winter/ Eagle F1 245/40/18 (Summer) mazdaspeed Ariel BC Coilovers Removed the splash guard and resonator box Febi Bilstein Prokit Rear Drop Links Short Shift Plate(Spamface) CFM Rear Motor Mount (9 PEGS) JBR Pass Motor Mount 80a JBR Trans Motor Mount 88a JBR 125 RARB (Middle setting) Forge V2 BPV Stoptech Drilled Slotted Front/Rear Step colder NGK 6510 0.7mm gap (fitted 56,000 Miles) APT Long Downpipe EGR Delete (fitted 56,000 Miles) Coolant bypass RX8 Alloys 3Bar Map Sensor and Harness (fitted 56,000 Miles) Banjo Bolt Motul GEAR 300 LS 75W-90 Fully Synthetic Car Limited Slip Differential Oil(Changed@59,292) Shell Helix Ultra 5W-40 Fully Synthetic Engine Oil ( Changed every 6/7000 miles) MOTS DONE@ Ambleside Motors
Gav1888
Post subject: Re: Hi Posted: Wed Feb 18, 2015 2:27 pm |
Has thanked: 56 times
Been thanked: 28 times
BanzaiMike
Post subject: Re: Hi Posted: Wed Feb 18, 2015 2:31 pm |
Joined: Sun Sep 16, 2012 8:00 pm Posts: 2275 Location: Stockport Vehicle: MPS2
Has thanked: 3 times
Been thanked: 26 times
Welcome to the nuthouse, prepare to have your money removed for many many modz and powerz
_________________ New motor - 2015 Mazda 2 Skyactiv 115 Sport Nav Previous motor - 2010 Mazda 3 MPS running BNR S3 Snail and the usual bolt ons.
Post subject: Re: Hi Posted: Thu Feb 19, 2015 6:57 pm |
Nice low miles  my 08 is only on 24k
max_db
Post subject: Re: Hi Posted: Thu Feb 19, 2015 8:32 pm |
Joined: Sun Feb 01, 2015 10:22 pm Posts: 149 Location: Bexhill Vehicle: MPS3 mkI aero
Been thanked: 3 times
And in under 2 weeks ownership someone has smashed into the front drivers side of it when it was parked up :( Pissed off is an understatement. Hope it doesn't get written off..
Gav1888
Post subject: Re: Hi Posted: Thu Feb 19, 2015 8:50 pm |
Ouch unlucky mate sorry to hear that......hope everything goes ok with insurance...
max_db
Post subject: Re: Hi Posted: Fri Feb 20, 2015 6:32 pm |
Attachment: 1512814_10152652020277401_2805371539656724401_n.jpg Attachment: 11018820_10152652398687401_1232695253202915036_n.jpg
You do not have the required permissions to view the files attached to this post.
Users browsing this forum: Google Adsense [Bot] and 13 guests |
