dgiannitakis
Post subject: Re: NEW MPS 3 MEMBER FROM ATHENS - GREECE Posted: Wed Jun 09, 2010 5:34 pm |
Joined: Wed May 12, 2010 9:18 am Posts: 11 Vehicle: MPS3 mkI
Thank you all for the welcome It would be honoured to see you on our web place here in Greece http://www.mazdaspeedclub.gr/forum/portal.phpHere, it' s a dyno diagram from my MPS3 4 months ago with Fugita CAI and Ecutek reflash...
MazdaTech
Post subject: Re: NEW MPS 3 MEMBER FROM ATHENS - GREECE Posted: Wed Jun 09, 2010 5:47 pm |
| Founder |
Joined: Sat Feb 06, 2010 11:34 am Posts: 4199 Location: Wiltshire Vehicle: Honda
Nice.
daviemps
Post subject: Re: NEW MPS 3 MEMBER FROM ATHENS - GREECE Posted: Wed Jun 09, 2010 5:54 pm |
Joined: Sat Feb 06, 2010 11:45 am Posts: 6734 Location: Glasgow Vehicle: MPS6
_________________ Titanium 6MPS, Cpe XL TIP/CAI, AEM Filter, PTP HPFPI, NGK Plugs, Forge recirc valve, C&C Custom 3'' System, Cpe RMM, J-Speed SSP, Eibach pro springs, Gloss Black RX-8 Wheels, Falken rubber, M-Tech D&G disc with yellowstuff pads all round, HEL BBL, DOT5.1 Fluid, Red Calipers, Black out badges and Tints. To fit = Hd lip, Sure Anchors 289bhp & 295ftlb
shurm
Post subject: Re: NEW MPS 3 MEMBER FROM ATHENS - GREECE Posted: Wed Jun 09, 2010 5:56 pm |
Joined: Sat Feb 06, 2010 5:58 pm Posts: 606 Vehicle: other
_________________  If it isn't broke dont mess with it !!! (Well not much !!)
Mal MPS 6
Post subject: Re: NEW MPS 3 MEMBER FROM ATHENS - GREECE Posted: Wed Jun 09, 2010 6:14 pm |
Joined: Sat Feb 06, 2010 7:47 pm Posts: 414 Vehicle: MPS6
Welcome to the forum, .........ouzo all round for everyone! Im up for a meet in athens.... could stop off at the "ring" on the way
Nasos Mazdaspeed 6
Post subject: Re: NEW MPS 3 MEMBER FROM ATHENS - GREECE Posted: Wed Jun 09, 2010 6:59 pm |
Joined: Wed Jun 09, 2010 6:54 pm Posts: 86 Vehicle: MPS6
dgiannitakis
Post subject: Re: NEW MPS 3 MEMBER FROM ATHENS - GREECE Posted: Wed Mar 21, 2012 8:53 pm |
SPECS (stock internals) ECU UPGRADE BY RE-ACTIONENG 76mm CUSTOM DOWNPIPE+EXHAUST FULL-RACE MANIFOLD KW V3 COILOVER XYZ 6-PISTON FRONT BRAKE KIT EBC BLUE FRONT STUFF PADS SPC REAR CAMBER ARMS WHITELINE CONTROL ARMS - LOWER INNER FRONT/REAR BUSHINGS HOTCHKIS SWAY BARS ULTRA RACING FRONT STRUT BAR ACT ORGANIC DISC-CLUTCH AND FLYWHEEL CP-E FMIC CUSTOM HPFP CUSTOM GEAR SHIFT ANCHORS CUSTOM REAR BRAKE LINES NGK 1 STAGE COLDER HEAT RANGE MSD DASHHAWK FUJITA CAI CP-E NVICSID PIPE CP-E INJECTOR SEALS TURBOSMART BOV PT-PERFORMANCE INTAKE COOLER KIT PT-PERFORMANCE BALANCE SHAFT DELETE PT-PERFORMANCE WINDAGE TRAY PT-PERFORMANCE PCV FIX CUSTOM PASSENGER-TRANSMISSION-REAR MOTOR MOUNTS PIRELLI P-ZERO 225/40/18 INOVIT CTS GUNMETAL 18x7,5
dgiannitakis
Post subject: Re: NEW MPS 3 MEMBER FROM ATHENS - GREECE Posted: Mon Apr 02, 2012 7:49 pm |
martin_46
Post subject: Re: NEW MPS 3 MEMBER FROM ATHENS - GREECE Posted: Tue Apr 03, 2012 10:10 am |
Joined: Mon Jul 26, 2010 7:52 pm Posts: 3761 Location: Aberdeenshire Vehicle: MPS3 mkII
dgiannitakis wrote: Looking good, you need an Aero spoiler though
_________________ Trying to resist modifying my new Mazda 3 mk2 MPS! viewtopic.php?f=86&t=13680
dgiannitakis
Post subject: Re: NEW MPS 3 MEMBER FROM ATHENS - GREECE Posted: Fri Oct 18, 2013 4:13 pm |
SPECS (stock internals) ECU UPGRADE BY RE-ACTIONENG 76mm CUSTOM DOWNPIPE+EXHAUST FULL-RACE MANIFOLD KW V3 COILOVER XYZ 6-PISTON FRONT BRAKE KIT EBC BLUE FRONT STUFF PADS SPC REAR CAMBER ARMS WHITELINE CONTROL ARMS - LOWER INNER FRONT/REAR BUSHINGS HOTCHKIS SWAY BARS ULTRA RACING FRONT STRUT BAR ACT ORGANIC DISC-CLUTCH AND FLYWHEEL CP-E FMIC CUSTOM HPFP CUSTOM GEAR SHIFT ANCHORS CUSTOM REAR BRAKE LINES NGK 1 STAGE COLDER HEAT RANGE MSD DASHHAWK FUJITA CAI CP-E NVICSID PIPE CP-E INJECTOR SEALS TURBOSMART BOV PT-PERFORMANCE INTAKE COOLER KIT PT-PERFORMANCE BALANCE SHAFT DELETE PT-PERFORMANCE WINDAGE TRAY PT-PERFORMANCE PCV FIX CUSTOM PASSENGER-TRANSMISSION-REAR MOTOR MOUNTS PIRELLI P-ZERO 225/40/18 INOVIT CTS GUNMETAL 18x7,5 http://s0.uploads.im/YIfOu.jpghttp://s0.uploads.im/Oe7u0.jpghttp://delectronics.gr/dt_portfolio/mazda-mps-dimitris/
Last edited by dgiannitakis on Sun Dec 28, 2014 10:10 am, edited 2 times in total.
Post subject: Re: NEW MPS 3 MEMBER FROM ATHENS - GREECE Posted: Fri Oct 18, 2013 4:23 pm |
Nice spec mate.
Can you provide a link or part code for the front blue stuff pads. I could only find them for the Mazda 3 Mps. How do you like them? Thanks.
dgiannitakis
Post subject: Re: NEW MPS 3 MEMBER FROM ATHENS - GREECE Posted: Fri Oct 18, 2013 4:32 pm |
Post subject: Re: NEW MPS 3 MEMBER FROM ATHENS - GREECE Posted: Fri Oct 18, 2013 4:59 pm |
dgiannitakis wrote: http://ebcbrakes.com/product/ebc-disc-pads-for-racing SpamFace wrote: Can you provide a link or part code for the front blue stuff pads.
Thanks mate, yeah as I thought, only for the 3, shame really. I was clutching at straws though seeing as this is the 3 section
Benz
Post subject: Re: NEW MPS 3 MEMBER FROM ATHENS - GREECE Posted: Fri Oct 18, 2013 7:15 pm |
Joined: Thu Apr 11, 2013 1:24 pm Posts: 947 Location: Stirling, Scotland Vehicle: other
Hello and Car looks really nice + lengthy spec sheet. I quite like the EBC BLUE FRONT STUFF PADS. Will look into getting it. How does it compare to OE pads or others that you may have used previously?
dgiannitakis
Post subject: Re: NEW MPS 3 MEMBER FROM ATHENS - GREECE Posted: Sat Oct 19, 2013 5:51 am |
XYZ included green pads for race use causing warped rotors so I end up with blue ones plus new rotors.
