Page 1 of 2 [ 26 posts ] Go to page 1, 2  Next
 Post subject: 1st Tune
 Post Posted: Sun Jun 14, 2015 5:16 pm
Bhp: 395
lbf·ft: 385
so i take delivery of my Mk2 MPS on thurs/fri.
had a look on the internet for some uk tuners. Litchfield stood out as my friend has had his GTR worked on a few times there. Anybody had any Mazda experience with them?? stage 1 map takes it to around a claimed 295bhp.....
 Post subject: Re: 1st Tune
 Post Posted: Mon Jun 15, 2015 12:32 am
They're great with the gtr, but NOT a Mps.
Versatile or Cobb access port should be the only way considered to map the MPS safely
you want a HPFP internals upgrade before a remap
 Post Posted: Mon Jun 15, 2015 4:54 am
Bhp: 395
lbf·ft: 385
Any recommendations on the pump?? Best to go with what is tried and tested. I was looking at the Cobb too. I believe they do a v3 and internals as a package??
Hybrid BNR4 Turbo, grimspeed 3 port, 3 bar map sensor, EGR delete, Vibra REM, 2nd Decat, Res Delete, Autotech HPFP, Cobb V3, HDI FMIC, Cobb Shift Weight, Shifter Bushings, Ksport 356mm BBK with Yellow stuff pads, Rear Stoptech pads, short shift plate, 3.5 HTP intake, Carbon scoop, Hardrace drop links, Whiteline RARB, whiteline front lower strut, Heko wind deflectors, Perm plate, damond twin OCC, Hel brake lines, typ200 fluid, GFB recirc valve, catless DP, Small battery and tray, AEM PI meth kit with DO failsafe, JMF intake manifold, V3 Exhaust manifold, JR3 Alloys, BC coilovers, Forged Manley rods and 88mm Pistons, race big end bearings, Keyed and polished crank, Southbend stage 3 endurance clutch + Flywheel, Stratified guardian angel, WOTbox, EONON head unit, Engine dress kit, CS exhaust mani cover, JTuned FTW
 Post Posted: Mon Jun 15, 2015 5:34 am
Been thanked: 9 times
Bhp: 265
Nate from new age does autotech internals and Cobb v3 and I believe a rear engine mount for a deal buying from the states normally works out the cheapest option.. Most have autotech internals but there are others out there (corksport etc etc)
Regards to the tune its entirely up to you who you use for it a lot of big names in the states for tuning these or a lot of people on the forum use Justin over here j believe his done well over 100 mps now
k&n typhoon..
Cobb v3
Auto tech internals
Wind deflectors
Sonic tuning coilovers
J-tuned
to come..
2nd decat
Bigger brakes
 Post Posted: Mon Jun 15, 2015 6:10 am
Bhp: 395
lbf·ft: 385
Ah ok. Excuse my inexperience....!! The last cars I've had tuned I just handed over to KTec racing with some £££ and said there u go, do something with it.
 Post Posted: Mon Jun 15, 2015 6:12 am
Bhp: 395
lbf·ft: 385
I do like the look of the Cobb though. All the little extras you can use it for. Etc.
 Post Posted: Mon Jun 15, 2015 12:10 pm
Bhp: 290
When Kenny says Versatile he means Versatune :P That or a COBB Accessport and then Justin to remap is the best / easier and probably cheapest combination you'll get for the MPS. Of course HPFP internals first like above :)
 Post Posted: Tue Jun 16, 2015 7:19 am
 Post Posted: Wed Jun 17, 2015 6:13 am
Bhp: 395
lbf·ft: 385
Hi all, thanks for the welcomes. Another question........ Is it better to upgrade the current recirc valve or upgrade to a 50/50 atmospheric?? If so, do any of you gents know of one that doesn't make too much of a noise..?!? Strange question but in my house apparently it's illegal to be 32 and want to drive a car that makes all sorts of "boy racer noises". My wife's words, not mine...!!!
 Post Posted: Wed Jun 17, 2015 11:22 am
Give her a slap with a wet fish.
Upgrading the recirc daily want do anything till you start upping the boost, the OEM one is plenty good enough.
A forge v2 would be ideal for you though, gives a wee bit of noise but nothing major, but won't really hear that until you change your intake. ££££££ spending begins haha
 Post Posted: Wed Jun 17, 2015 11:57 am
Bhp: 395
lbf·ft: 385
Got to be very discrete with how I go about things. Luckily a close friend is the mechanic at Mazda main dealer...... Cheap labour to do bits and pieces. Just built himself a 435hp Evo 6 from shell so I'd imagine he's got the qualifications.
 Post Posted: Wed Jun 17, 2015 12:05 pm
As Sir-SpamFace says you won't really much of the recirc until you upgrade your intake.
It's a really easy job to do though and a good one to build your experience and confidence with.
 Post Posted: Fri Jun 19, 2015 8:21 pm
As stated by spam flaps if you want noise then the first best mod is a decent intake.
A HTP intake and then a Forge V2 recirc will give you lots of whooshy dearth vader noises and turbo sneezes through the intake
 Post Posted: Sun Jun 21, 2015 7:06 pm
Welcome along. Enjoy your new car.
 Post Posted: Tue Sep 08, 2015 5:24 pm
Bhp: 395
lbf·ft: 385
Hi gents, So I'm ready to begin some light mods..... was thinking of the rear engine mount and possibly rear sway bar to keep the ass in check a bit better. Any advice on where is best to buy???
