Page 1 of 2 [ 22 posts ] Go to page 1, 2  Next
 Post subject: potentially new 6mps owner.
 Post Posted: Thu Dec 05, 2013 4:33 pm
Hi all seriously looking at getting myself a mps very soon,going to view one this sunday hopefully.ive been doing my homework so know what to look for,its this one if anyone recognises it,has a good spec and some money spent on it.
http://www.ebay.co.uk/itm/2006-MAZDA-6- ... true&rt=nc
should i be concerned about the cobb?dont know much about them.
thanks
simon
 Post subject: Re: potentially new 6mps owner.
 Post Posted: Thu Dec 05, 2013 6:02 pm
anyone?appreciate I'm new but thought someone might of replied after 47 views:)
 Post Posted: Thu Dec 05, 2013 6:08 pm
The Cobb Ap is a great bit of kit, the V3 is the newest version with a better screen, lots on here use them, me included, can be used to tune or you can use valet mode if going to the garage ,there's even an anti theft map, had my 6 just over a year and love it, tuning can get addictive tho........and pricey!
 Post Posted: Thu Dec 05, 2013 6:20 pm
ok great,so the maps installed are all safe and checked?owner reckons his is running around 290/300 bhp.do they need to be set up by a tuner?or can anyone install a map from the cobb website?just concerned for the engines health.
 Post Posted: Thu Dec 05, 2013 6:24 pm
I can't comment on the cobb from a personal perspective, but from the reading I've done on here it's a great bit of kit and I would buy one myself if I was to start from scratch.
My concern would be the competency of the guy using the software and what map he is running - worth asking some questions before buying (especially given that he appears to have used his camera upside down :lol: :lol: ). To be fair, it sounds like he is either knowledgeable on the mps or has done some reading before selling, as the vvt change is a big plus (very common issue and approx. £450 for the parts). The air intake is also a "must have" mod - worth asking some questions about what type etc. Also, I'm pretty sure there was a recall on the car for the bubbling alloys, so good that the wheels have been done.
All in, if the seller can answer the questions and give you some confidence, I would say that it's a good buy for the age and mileage.
Have you driven a 6mps before? Where are you based?
 Post Posted: Thu Dec 05, 2013 6:28 pm
Hi garry,my main concern is the software being used,so will ask a few questions,never driven an mps before,I'm in st albans,herts,
used to a r33 gtst for 3 years but sold that around 2 years ago,now drive a m4 golf 2.3v5
 Post Posted: Thu Dec 05, 2013 6:42 pm
you can download maps off the Cobb website to match the mods you have, or in my case off the JBR website as I have their intake, you can go from stage 1 stock up through various increases-I have a stage 2 off the shelf (free) map on mine and the improvement is amazing, the tunes are regarded as safe -some would say safer than stock. A custom map or etune can also be done using Cobb which is even better. Also very useful tool for reading error codes and monitoring stuff like knock,boost Afr's looked at the ad and it says lots of the right things, VVT done etc which is an expensive job, would definitely think it worth a look.
 Post Posted: Thu Dec 05, 2013 7:03 pm
It seems good .
make sure you check all the usual car stuff , see if he has any reciepts for the work done etc .Make sure it drives true and straight then make sure everything works.screen wash , all the windows etc.
good luck and you might end up with a fast bargain barge
 Post Posted: Thu Dec 05, 2013 7:58 pm
Yeah think I could be on to a winner.asked him about turbo seals and diff mounts.all good he said.says he has a banjo bolt for the turbo oil feed to reduce pressure? This a common mod?
 Post Posted: Thu Dec 05, 2013 8:49 pm
Don`t forget to check out the air con. Can be expensive to fix.
 Post Posted: Thu Dec 05, 2013 11:11 pm
think my search continues!just did a basic reg text check,came back as a cat c damage back in 2011!
 Post Posted: Fri Dec 06, 2013 5:34 pm
Not good mate! Never mind tho as there's plenty more out there.
 Post Posted: Fri Dec 06, 2013 9:12 pm
Bit gutted as its local to me and had quite alot of work done and some nice mods.the owner is more shocked as he didnt know! Didnt do a check before buying.now stuck with a car people wont want.
 Post Posted: Sun Dec 08, 2013 7:14 pm
Any idea as to what its worth now its a cat c?
 Post Posted: Sun Dec 08, 2013 8:37 pm
Depends where the damage was and how good it was repaired.
