chri5young
Post subject: Hello....need some advise ! Posted: Sun Sep 25, 2011 4:39 pm |
Joined: Sun Sep 25, 2011 4:16 pm Posts: 5 Location: Banbury, Oxfordshire Vehicle: MPS6
Hi all... I have a bit of an issue with my 2006 Mazda 6 MPS....and wonder if the problem has an easy/obvious solution It had a service last week and from running very well with no problems whatsoever it now seems to judder quite badly under acceleration above 4,000rpm. Under normal driving, cruising speeds and gentle acceleration all is fine...in fact I drove 180 miles back from Wales today and with cruise-control on at 75-80 mph all was ok. However, any kind of fun results in an apparent loss of power and quite heavy juddering. The garage who did the service is not a Mazda specialist and has changed the spark plugs already but to me it seems more like a fuel/air mix issue or turbo problem....again I need to stress that the car ran perfectly well before the service. I haven't checked with a franchised dealer yet because of serious problems I encountered with the Mazda dealer I bought the car from. Any suggestions greatfully appreciated Regards Chris
Maestro
Post subject: Re: Hello....need some advise ! Posted: Sun Sep 25, 2011 4:44 pm |
Joined: Sun Sep 19, 2010 6:39 pm Posts: 2783 Vehicle: other
Sounds exactly like what I had a week or so ago. Turned out to be plugs. The fact that a non-Mazda specialist has done your plugs (same as me again - will do them myself from now on!) leads me to conclude that you've got incorrectly gapped plugs in. What plugs did you put in?  Read = THIS= thread if you can be arsed. Better still, just go outsid and put your old plugs back in and be amazed that your car works again
_________________ BMW 330D M Sport
KevMS6
Post subject: Re: Hello....need some advise ! Posted: Sun Sep 25, 2011 4:46 pm |
Joined: Sun Jul 11, 2010 9:01 am Posts: 9450 Location: Morayshire Vehicle: MPS6
Been thanked: 3 times
I'd say incorrect spark plugs fitted... Lots of similar issues lately and spark plugs have been the problem. Find out what ones they fitted and get a new set of standard ones fitted
_________________ ••Black Mazda 6 MPS••BNRstage1 // CpeIntercooler // Cpe3"SRI // CpeDiff brace // HTP3"tip // eBay3"Downpipe w/magnaflow 200 cell cat // AutotechHPFP // SnowPerformancemeth injection w/Aquamistjet/adaptor // Amsoilair filter w/prefilter // GoFastBitsBOV // NGKIridium IX plugs // TurbinetechDiff mount // BilsteinB12 // eBayStiS204 front lip // Whitelinerarb // OZprodrive Rx-8 alloys link to pics/mods
chri5young
Post subject: Re: Hello....need some advise ! Posted: Sun Sep 25, 2011 5:26 pm |
cheers guys....many thanks.... I will take it back tomorrow and insist on another set. Can't check old ones as they have been thrown out. Fingers crossed !!!
KevMS6
Post subject: Re: Hello....need some advise ! Posted: Sun Sep 25, 2011 5:29 pm |
Get them to double check there numbers and be sure it's for the MPS
Maestro
Post subject: Re: Hello....need some advise ! Posted: Sun Sep 25, 2011 6:09 pm |
And make sure they're gapped correctly! There've been a tonne of incorrectly gapped plugs reccently and they should be 0.8mm
bigfish
Post subject: Re: Hello....need some advise ! Posted: Sun Sep 25, 2011 6:30 pm |
Joined: Mon Aug 16, 2010 7:37 pm Posts: 1020 Location: Barnsley Vehicle: MPS3 mkI aero
Bhp: 280
agree with the plugs suggestion, either badly gapped or the wrong type.
_________________ Sure Aeros SRI Sure Sidewinder TIP and Sure Return. Goodyear Eagle F1 Asymmetric 2's. NGK ILTR6A-8G Spark Plugs.
foxy
Post subject: Re: Hello....need some advise ! Posted: Sun Sep 25, 2011 6:35 pm |
Been thanked: 60 times
chri5young
Post subject: Re: Hello....need some advise ! Posted: Fri Sep 30, 2011 12:16 pm |
NGK ILTR6A-8G plugs fitted and all is well !!!
Thanks for the feedback
;o)
