Page 1 of 1 [ 7 posts ]
 Post subject: REAR DIFF VIBRATION CURED!!!
 Post Posted: Mon Sep 10, 2012 5:34 pm
Hi Guys,
After one year of suffering from severe vibrations with WOT in first gear I finally had the Sure Dreadnaught Rear Diff Mount installed by X0 Performance and what a difference. (Top guys) It is like night and day, vibes are completely gone and the car drives just as it should now and am chuffed to bits :-) I highly recommend this mod to anyone with an MPS 6.. :thumbs:
Next on the list is a sure rear engine mount, Tip and SRI then back to XO for a map...
Hoping for 300bhp from the above, however what are these engines capable of without spending mega bucks?
 Post subject: Re: REAR DIFF VIBRATION CURED!!!
 Post Posted: Mon Sep 10, 2012 5:44 pm
You'll certainly have a big grin once you get the map done :D
 Post Posted: Mon Sep 10, 2012 5:53 pm
indeed, i have the map and intake etc, but want the diff braces!
Bet that wasnt cheap!
 Post Posted: Mon Sep 10, 2012 6:23 pm
The Dreadnaught Rear brace was £320 supplied and fitted and that also included rear diff oil change with millers... Bargain for me as it has caused no end of problems, so worth it...
Does the map really make that much difference? Cant wait : shifty :
 Post Posted: Mon Sep 10, 2012 6:34 pm
Indeed it does! The car will do exactly as it says in the tin, zoom zoom!!
Not that it doesn't from stock though :)
Tip and map will more likely give you 290 ish.
Goodstuff, its like night and day tbh :thumbs:
Around the 300bhp/300ftlbs i would say
 Post Posted: Mon Sep 10, 2012 7:52 pm
Me too,think its gonna be my next mod along with engine mount :thumbs:
Users browsing this forum: Google [Bot] and 2 guests
