Register    Login    Forum    FAQ
Board index » Mazda 6 MPS » Running gear
 Page 1 of 1 [ 12 posts ]
 Post subject: transfer box bearing
 Post Posted: Mon Jul 09, 2012 9:33 am
Hi all, anybody have a clue on price/labour for a transfer box bearing an where to source the parts, i have movement in my driveshafts an believe its down to this, any clues on this guys???
//CORKSPORT STAGE 2 SRI+TIP//FORGE BPV V2//MILLERS 5W30//NGK LASER IRIDIUM PLUGS//C+C 2ND DECAT//CP-E REM//T-MPS BANJO BOLT//RED CALIPERS//6K HEADLIGHTS//
TO COME; 30MM EIBACHS//MILLERS CFS 5W40//FORD G-BOX OIL//
 Post subject: Re: transfer box bearing
 Post Posted: Mon Jul 09, 2012 6:24 pm
Bhp: 401
lbf·ft: 406
mazdaspeedforum m8.search there and you will find a thread on uprated bearing and clamp for it
CORKSPORT TMIC,jetex cbe and 3" dp fully cat less with vband,kmd internals,ported intake,flaps delete,tigs,inj seals,egr delete,forge recirc valve,throttle bypass,cpe rear diff brace,sure front diff mount,h&r springs,rear antiroll bar,front & rear upper and lower chassis braces,rear subframe brace,mtech brakes,awr rmm,devils own meth,bnr3 turbo,boost dial.3.25 sure intake,htp3" tip ,2007 cold pipe,cold air box,fully forged and lower compression by myself .
Tuned with
Imageby justinEtune
 Post Posted: Mon Jul 09, 2012 6:48 pm
I will price up bearings tomorrow at work mate.. need them my self:).. labour will be mega i would think as the subframe needs dropped.
Chris
MS06MPS -Black Mica -Saikou Michi OCC -SteetUnit Rear Mount -HEKO wind deflectors - H&R's - Satin black RX8 rims. and a knackered transferbox........
 Post Posted: Mon Jul 09, 2012 7:26 pm
Bhp: 401
lbf·ft: 406
subframe takes 25mins to drop out
Tuned with
Imageby justinEtune
 Post Posted: Mon Jul 09, 2012 7:48 pm
aye not by the book to you and i, that you gining a quote of 60 mins labour for the removal and refit of the frame? :lol: hour for box and bearing replacement? lol
Chris
 Post Posted: Wed Jul 11, 2012 8:46 pm
Bhp: 401
lbf·ft: 406
doings kevs dp on sunday,we will time the frame removal
Tuned with
Imageby justinEtune
 Post Posted: Wed Jul 11, 2012 8:49 pm
cool:P... forgot to grab a price. been flat out. just put a reminder in my phone lol.
Chris
 Post Posted: Tue Jul 17, 2012 1:33 pm
Did your bearing cause any noise, ie low speed 30-40mph? Or is it just play . ?is it normal for the drive shafts (front)to have in and out play?
 Post Posted: Tue Sep 18, 2012 10:53 am
Hi guys, after an update on this please, just wondering if anybody has carried out this fix yet, cost of parts, ie bearings/clamp, the knocking in my drive shafts is gradually getin worse on both sides, cant seem to find parts/price anywhere, all help much appreciated, cheers.
 Post Posted: Tue Sep 18, 2012 12:02 pm
Forum Trader
Lock nut - 0223-27-012 £6.42
Lock washer - 0223-27-012 £6.51
Pinion bearing#1 - LN01-27-210 £37.32
Pinion bearing#2 - 0755-27-210 £38.32
Distance piece - GC0127171 £4.84
this it what you need all items in stock
MAZDA 6 mps ,COBB AP ,Fully forged motor,sure bsd, t-mps head,t-mps intake manifold,sure tigs, sure halos,t-mps cooler,sure full aero 3.25 GT intake, sure shortcut,anchors,conterweight,su turbo manifold,gt35gtx turbine,turbosmart dual port bov,sure dreadnought & juggernought rer diff mounts,tactrix 3 port boost solenoid, sure ags,autotech fuel pump,custom fuel system, millers engine and gear oils, yellowspeed coilovers t-mps spec, stoptech discs,ngk plugs depo gauges i think thats it might of forgot a few things
 Post Posted: Tue Sep 18, 2012 4:04 pm
Thanks 4 tha, il b in touch soon :thumbs:
 Post Posted: Fri Oct 12, 2012 12:47 pm
hi guys, also after some help on this. my bearing needs to be replaced but so does the oil seal. have sorted the bearing but no one can get me the right seal.
can anybody point me to a supplier in the UK. i've tried my local mazda dealer with no luck.
any help would be greatly appreciated as i currently have a great car going nowhere.
cheers
